Tractor Talk Discussion Forum
Bubbles in radiator
other Will
06-27-2006 14:32:56
This is a car but would be the same in a tractor. When I rev the engine (50 mph. Under 50 ok) I get bubbles in the rad. Drive for a while at that speed and it starts to foam and loose water. How can I tell if it is the head gasket, cracked head, water pump sucking air, or something else?
JD9295
06-27-2006 23:03:36
 Re: Bubbles in radiator in reply to other Will, 06-27-2006 14:32:56
buickanddeere, I havent heard anyone say to make the plug with the airline in years, that was something always in my grandpas toolbox. I thought he was the smartest man in the world forst time i watched him put new valve seals in using the old plug. Auto zone does have them now, if you patronize the idiots. But making it yourself is more gratifying
buickanddeere
06-27-2006 20:13:27
An old sparkplug with an airline from the shop compressor brazed on. Apply air to the cylinder when both valves are closed. Listen at the rad, intake, exhaust, oil filler and around the head gasket. Make certain the engine doesn't kick over under air pressure and cause an injury.
Tramway Guy
06-27-2006 16:49:38
Yes, it sounds like you have a bad head or gasket. Some garages have testers to see if the bubbles contain combustion products, which would confirm that theory.
Ray
06-27-2006 16:29:15
You can take the fan belt off and run it so the pump won't turn.
Allan In NE
06-27-2006 16:05:28
Will,
Is it a 3.0 Ford engine?
Allan
other Will
06-28-2006 08:55:42
 Re: Bubbles in radiator in reply to Allan In NE, 06-27-2006 16:05:28
It is a 1938 Dodge.
Buzzman72
06-28-2006 06:46:25
Allan, from my experiences at the dealership, I'd suggest a 3.8 if it's a Ford. There was a headgasket recall on those, while the 3.0 was relatively trouble-free.
lucasss
06-27-2006 15:01:28
probably a head gasket or cracked head. you can take the water pump off and see if the impellars are worn off. i dont think ive ever seen a waterpump pump outside air into a cooling system. lucas
