Tractor Talk Discussion Forum
Ok boys put on your thinking caps on for this one
old
06-29-2006 13:02:48
Thanks guys I now know what I need with your help. The measurement is for the tucker fingers on a baler
Roger in Iowa
06-29-2006 16:19:59
 Re: Ok boys put on your thinking caps on for this in reply to old, 06-29-2006 13:02:48
If it is for a JD baler, set them close to the needle as you can without touching. Then set the pull rod so when you pull the tip to left, with the tucker finger in the home position, it is even with the slot in the bale chamber.
Make sure they do not get hung up in the full stroke position. Don't lube any of those parts or the dust will collect and really give you fits!
Roger in Iowa
MN Bob
06-29-2006 13:52:51
Old; Must be a JD baler. Just had the same problem on my 336. Miked a few things. Those plastic tie wraps for cables etc? one size I had on hand was 2/32. Figured tight or light drag was in order so went with that. I will have to get some pictures of my "rebuild of the fingers for you. Worked great and bales are in shop. Good luck, Bob
