Tractor Talk Discussion Forum
Starter
Matt Kane
06-30-2006 13:31:50
How can a weak starter affect a diesel?
RAB
06-30-2006 14:35:50
 Re: Starter in reply to Matt Kane, 06-30-2006 13:31:50
Apart from not actually starting, the injection equipment is steadily sqirting unburned diesel into your engine. While gas oil may have some lubricating properties it is nowhere near as good as oil lubricants. So it can not be good, washing away the lubrication from the bores etc.
It is well known that the highest engine wear rate takes place after cold starts and before the lubrication system is up to full efficiency and the engine is warmed.
Regards, RAB
John T
06-30-2006 13:42:52
Matt, if the starter (or batterys or cables or solenoid etc) is weak enough that she cranks over slow it can be hard to start is what comes to mind, other then that it dont have any affect once shes running.
John T
Matt Kane
06-30-2006 13:44:55
 Re: Starter in reply to John T, 06-30-2006 13:42:52
Runs fine after I start it.
RustyFarmall
06-30-2006 13:40:33
Diesel engines have very high compression and require a strong starter just to turn them over. If the engine will not turn over it will not start.
Allan In NE
06-30-2006 13:39:18
Big time,
Starter, batteries and cables all determine (along with the compression) how easily they start.
Allan
Matt Kane
06-30-2006 13:43:59
 Re: Starter in reply to Allan In NE, 06-30-2006 13:39:18
Okay, Ill have to take it to a rebuild shop and test it. I have a new 1 wire alternator, new 2/0 Cables, and a new Diesel Battery and its hard starting. Is there anything I can do to repair the starter?
RN
06-30-2006 14:06:13
 Re: Starter in reply to Matt Kane, 06-30-2006 13:43:59
New brushes, good cleaning help. Arcing from brush wear need a bit of polishing. Main shaft bushing may need replacing if it has too much slop. Electric shop would have precise calipers and guages. . RN
old art
06-30-2006 15:09:17
 Re: Starter in reply to RN, 06-30-2006 14:06:13
take each cable off and clean the end also the surface it is fastened to . have seen where the starter was off and the mounting hole aera was painted cleanthat paint off and the styarter flange also this all adds up to more resistance. dont ignore the battery have it tested. hope this helps old art.
