Tractor Talk Discussion Forum
Farmall C Serial # 9427
48C-MAN
06-30-2006 14:31:11
Is it possible that this C with serial # 9427 has a water pump? The reason I ask is because it has a 7 psi cap on the radiator and it is my understanding that the non-pressure cooling systems used a totaly different cap. Any help would be appreciated. Thanks
R. Pugh(NC)
06-30-2006 15:40:54
 Re: Farmall C Serial # 9427 in reply to 48C-MAN, 06-30-2006 14:31:11
Does it have a radiator? If not it must be air cooled and no water pump is needed!!!!! !!!
sammy the RED
06-30-2006 20:41:26
 Re: Farmall C Serial # 9427 in reply to R. Pugh(NC), 06-30-2006 15:40:54
R.Pugh(NC), Aahemm, Some tractors had radiators and did not use a water pump.
old
06-30-2006 15:18:06
Can't say if it does or doesn't but you can find out just by looking at the front of the engine. If the area where the fan is doesn't have a hose going there then you don't have a water pump but if it does then you have a water pump.
