Tractor Talk Discussion Forum
Mobile one oil
coflyboy
07-02-2006 07:15:14
I have used Mobile One oil for many years in all my 4-cylce engines except diesel with great success. Yesterday I read the splurbage on the can and it said you can use Mobile one for diesel.
Whadayathink??
TomTX
07-02-2006 18:15:25
 Re: Mobile one oil in reply to coflyboy, 07-02-2006 07:15:14
You can use regular Mobil One in diesels, but it not the smartest move. The "diesel" oils have additional additives for things like soot control, etc. If you want the best, get "Mobil Delvac One" which is a comlete synthetic for diesels, 5-W-40. Do not confuse with Mobil Delvac 1300, which is for diesels, but is regular oil. You can find the Mobil Delvac One at distributor or at large truck stops like Petro. Long haul truckers who are totally responsible for their own maintenance/repairs run a lot of Mobil Delvac One. Tom
Jay (ND)
07-03-2006 07:47:16
 Re: Mobile one oil in reply to TomTX, 07-02-2006 18:15:25
Yep, you're right. It's only for diesel cars and light pickups. Anything heavier than that and you want Delvac 1.
NC Wayne
07-02-2006 17:40:35
Being an independent mechanic I hear all the time from different customers or in trade magazines that this or that oil or grease is the best. I know there is some good stuff out there but in the end I take all of the hype with a grain of salt until I see actual proof of how it performs in real world service. We've got one customer that has used nothing but LE's oils and greases in his equipment for nearly 40 years and has never had a lubriation related failure. So, if you want the best oil around for gas or diesel engines, as well as the best grease out there check into Lubrication Engineers. We recently tore down a 3306 CAT engine out of his 235 excavator that had been run nearly every day for twelve years digging and loading trucks in his gravel pit. The problem with it was electrolosis had eaten a hole in two of the liners, other than that it ran like a top. We got her torn down and sent the crank off to be checked and ground or whatever it needed. They miked it out and the rods and mains all checked out as being standard, no grinding, polishing, nothing needed. Dad said in over 30 years of being a mechanic and building engines, including a few at a dealership where that's all he did, he'd never seen one come in standard like that...especially after twelve years of hard use. Like I said the customer had been using nothing but LE oil in the engine since it was build twelve years ago. I've got other examples of how good their stuff is but if that's not a testament to how good their oil is then I don't know one. Usually I'm skeptical when someone says "our stuff is the best" but in the case of LE, I've never seen better.
RM in Va.
07-02-2006 19:31:48
 Re: Mobile one oil in reply to NC Wayne, 07-02-2006 17:40:35
"So, if you want the best oil around for gas or diesel engines, as well as the best grease out there check into Lubrication Engineers."
THE BEST????? ???? Are you sure?? LOL LOL
Woodbeef
07-02-2006 12:02:30
Have you ever looked into Royal Purple before? I"ve used just about all of the synthetics over the years. RP is the best of the best! Only bad thing Amsoil can say about RP is that it contains Moly. The petroleum oil companies that make synthetics do not make as good of a product as the synthetic only companies. Street Commadores mag in OZ did a great comparison on synthetics,quite an eye opener really.
Don L C
07-02-2006 08:54:37
I have a Dodge Sprinter van, 3/4 ton, manufactured in Germany buy Mercedes Benz.....I was told by the dealer it came with Mobil 1 ...I have been using that , serviced by my dealer..... .
Jay (ND)
07-02-2006 07:30:17
Yes you can. For lightweight diesels. FOr heavy duty diesels, look for Delvac 1.
Jay
