Tractor Talk Discussion Forum
General Wiring Question with a Flasher Unit
Paul in On
07-04-2006 12:52:07
here we go. Wanting to wire a set of flashing lights onto a 6V system. The wire is hot before going onto the flasher, where it's marked P. But there's nothing when I connect the light a "L" This is the second flashur unit to rule out a faulty one, and the light works when I remove the flasher unit from the circuit. It is a 6v flasher, and I'v run out of ideas what to do. Thanks. Paul
willie j
07-04-2006 18:52:42
 Re: General Wiring Question with a Flasher Unit in reply to Paul in On, 07-04-2006 12:52:07
Paul
6 v 3 term flasher would be #229 regular, 235 heavy duty
Think you have 2 wires wrong. If I remember correctly, += hot, p=pilot(indicator) l=load.
the 229 should burn steady with 1 bulb, flash normal with 2, flash really quick with 3.
the 235 should flash normal with 1,2, or 3 bulbs.
HTH Willie
Paul in On
07-05-2006 06:52:31
 Re: General Wiring Question with a Flasher Unit in reply to willie j, 07-04-2006 18:52:42
I have a 535 flasher unit.
RayP(MI)
07-04-2006 15:48:45
Try using a heavy duty flasher unit. They have a built in resistor, don't rely on the resistance of the bulbs. Use in a 6v system may lead to a slow flash, or even no function.
dustin47m
07-04-2006 13:59:22
you need to make sure you have aa 6 volt flasher these are hard to find or put in a 8 volt battery this will let you use a 12 volt flasher usaled.com
Bob
07-04-2006 13:44:50
Do the lamps light steady with the flasher in the circuit?
If so, the current draw of the specific bulbs you are using is too little to make the unit "flash".
Is it a 2-wire or a 3-wire unit?
Paul in On
07-04-2006 18:22:33
 Re: General Wiring Question with a Flasher Unit in reply to Bob, 07-04-2006 13:44:50
Bob,
There is no light at all with the flasher unit in there. Secondly, it's a three wire unit, P = power - L = lights and X=indicator.
Bob
07-04-2006 23:09:56
 Re: General Wiring Question with a Flasher Unit in reply to Paul in On, 07-04-2006 18:22:33
You gotta get the identity of the terminals correct!
"X" = "input"
"L" = "load"
"P" = "Pilot", to operate an idicator light in the turn signal unit or dashboard, flashes in alternate sequence with the "L" terminal
Paul in On
07-05-2006 06:54:13
 Re: General Wiring Question with a Flasher Unit in reply to Bob, 07-04-2006 23:09:56
That'll do it -I'll go give her a try. That's what you get for assuming your right! Psul
