Tractor Talk Discussion Forum
ford 4000 cracked block
james magee
07-04-2006 13:37:18
hi, i have just discovered that my ford 4000 has got a cracked block about 25millimeters to the right hand side of the middle cylinder (looking up from underneath ). is there any way of fixing it ????? ??..
james magee
07-05-2006 14:25:36
 Re: ford 4000 cracked block in reply to james magee, 07-04-2006 13:37:18
thanks for help. sounds like that could be the reason for weakness in the 4000,its not used much so i will probably try something like search seal in radiator and take thermostat and radiator cap off to stop pressure, maybe have to ghange oil more often.
hay
07-05-2006 05:24:57
i have a friend that used to weld up cracked engine blocks on old tractors. i think he used a nickle rod on cast iron. maybe ask some local welders what they do.
james magee
07-05-2006 14:28:12
 Re: ford 4000 cracked block in reply to hay, 07-05-2006 05:24:57
i will a welder when i c one cheers..
RAB
07-04-2006 13:52:34
Is this the typical stress failure on these engines, when using the engine as part of the frame? If so, forget it and get the later criss-cross block which was more resistant to this type of failure.
Regards, RAB
james magee
07-05-2006 14:32:22
 Re: ford 4000 cracked block in reply to RAB, 07-04-2006 13:52:34
i think u could be right ill try to repair it with search seal or similer. cheers.
