Tractor Talk Discussion Forum
JD Model A oil fill dipstick EASY ONE
GScheu
07-05-2006 06:46:26
A friend recently fired up an inherited Model A-styled (circa 1952, SN 703267). He will be ordering manuals, but in the meantime can anyone tell me where the dipstick and oilfill tube are hiding?
Pappy
07-05-2006 16:47:00
 Re: JD Model A oil fill dipstick EASY ONE in reply to GScheu, 07-05-2006 06:46:26
The oil fill location is just above the clutch pulley. It is a pipe cap, about 1.5 inch diameter.
Your tractor will require 12 quarts of oil if you change the filter.
Allan In NE
07-05-2006 07:01:07
Should be a standpipe/cap up on the top to fill; check cock down on the lower right hand side to check.
There is no "dip stick" as such.
Allan
Tim...Ok
07-05-2006 08:42:10
 Re: JD Model A oil fill dipstick EASY ONE in reply to Allan In NE, 07-05-2006 07:01:07
Yep,like Allan says,it's tucked behind the front edge of the flywheel..open the check a couple turns and filler up till oil drips out..
Tim
Leroy
07-06-2006 05:04:04
 Re: JD Model A oil fill dipstick EASY ONE in reply to Tim...Ok, 07-05-2006 08:42:10
Not on a 52, on 34-38 yes but with the cover for the starter ring gear they were moved to the pully side under the pully
