Tractor Talk Discussion Forum
Electronic ignition in Allis Chalmers Model G Trac
AAAA
07-07-2006 18:14:40
If I put an electronic ignition module in the distributor do I need to use the mechanical advance parts in the distributor or does the electronic module take care of the timing advance? Thanks.
ben brown
07-07-2006 20:15:08
 Re: Electronic ignition in Allis Chalmers Model G in reply to AAAA, 07-07-2006 18:14:40
i tell you i have installed 4 set of the e-ingtion best thing that you can do for older tractors one on a 4000 4 cly. one on a 3 cly 4000 ford and two super c all are happy with them i do recomend you buy the coil with the ingtion set. best money you spend on your tactor. i did have to adjust the timing.
John T
07-07-2006 18:23:41
Leave the mechanical centrifugal advance in place. All the elec switch does is to trigger n fire the coil when a magnet passes by a pickup coil the same thing as when the high cam lobe opened the points. The base plate the pickup coil is mounted on (same as the points) will then still rotate and change in position relative to the magnet fixed on the cam to advance the spark. On much more fancy n complex high performance automotive ignitions the computer senses the RPM and electrically advances timing but on our old tractors we still use centrifugal advance and/or vacuum
To get the most bang for the buck and utilize all the advantages that elec switch can offer, I highly recomend you match it up with a high energy coil to replace the old stock coil also. CAUTION Dont forget to buy the switch to match the tractors polarity !!!!! !! and have them match up the high energy coil also.
John T
AAAA
07-07-2006 18:37:17
 Re: Electronic ignition in Allis Chalmers Model G in reply to John T, 07-07-2006 18:23:41
John T: Thank you for the reply to my question! Ha
