Tractor Talk Discussion Forum
Hornets HELP
RLH
07-07-2006 18:54:25
i just found a hornet nest by back door I heard of a poisin you mix with golden malern and something else can anybody help me with proper ingredents
Chick
07-10-2006 22:42:31
 Re: Hornets HELP in reply to RLH, 07-07-2006 18:54:25
That water hose trick won't work on paper wasps. Get the heck stung out of you everytime.
John Scott
07-10-2006 04:30:56
If you wait til after dark, use a bag and squeeze off the nest at the top.
I heard that if they are heading to the nest they won't sting you because they have food, but if they are coming out the nest, loook out!
tg in VA
07-09-2006 18:34:09
Use a water hose, stand back and put the hose on the hardest stream the nozzle will allow.The water dissolves the "paper" surrounding the nest, the water stream disburses the hornets and as they built the nest out of the elements, being soaked sort of demoralizes them. You can walk over and crush those that fall to the ground.
The nice thing about this method is there are no chemicals and a water hose is a low cost option.
I have a 100% success rate and have never been stung in the process.
Brad Wright of MO
07-09-2006 13:52:29
A tennis racket works good when there out of the nest anyway!
Richard Scott
07-08-2006 20:57:45
Burn your house down. Do it at night. Works every time.
Truth seeker
07-08-2006 18:37:54
Hi!
Starting fluid works very well too.
I did that when I found a wasp nest in the phone box.
When they were squirted they looked surprized and then "good night irene"
Couple secounds later, you coulden't tell what hit them cause it leaves no residue.
No smoking though!
and $0.99 a can beats most everything else.
Just my two cents.
vjd
07-08-2006 15:33:23
Do it after the sun goes down so they are all in the nest
tinyy
07-07-2006 19:11:16
Just get some carb or break cleaner that will take care of them
hay
07-08-2006 05:48:14
 Re: Hornets HELP in reply to tinyy, 07-07-2006 19:11:16
brake parts cleaner. cheap and very effective.
john *.?-!.* cub owner
07-07-2006 19:41:17
over the ocunter wasp spary works good to.
