Tractor Talk Discussion Forum
Oh, Oh. Made 'er Mad
Allan In NE
07-07-2006 19:05:15
Well Phooey!
Two days ago, I'm makin' noises like I need another tractor to work on 'cause I was comletely done with the Hydro 70.
Wrong.
Must have made the ol' tractor mad 'cause today it up and dropped two cylinders on me. No noise, no prewarning, no nothing; just started running on four cylinders in the middle of a field.
Checked it out and it's got zero compression on #'s 2 and 3. Guess she maybe is jealous of me finding another? :>)
Allan
37 chief
07-08-2006 11:17:18
 Re: Oh, Oh. Made 'er Mad in reply to Allan In NE, 07-07-2006 19:05:15
If you think of all the things going up and, down, and around in these tractors, it's amazing more stuff don't go bad. Good luck finding the problem. Stan
the tractor vet
07-08-2006 08:17:03
Sounds like a classic case of blowen head gskt to me . Pull head mill head put back on torque to spec's warm up re torque to spec's . GOOD as new . Check timeing and octain rating of fuel good to go .
msb
07-08-2006 08:10:06
Hey Allen, sounds like you have a couple valves stuck open.Remove the valve cover and tap on the stems using some penetrating oil to free them up.After you get her running on all cylinders again,slowly pour about a half cup to a cup of brake fluid through the intake.That should clean the stems and guides up pretty good.
chris sweetland
07-08-2006 07:24:52
just adjust the carb untill shes running better again i had my to-20 running well on 3 cyl because i got it to run well again by adjusting the carb when i rebuilt the head it sure did have some more power
davpal
07-07-2006 21:36:41
Sound like you have a couple of valves stuck open. The valve cover removal should reveal the culprit. Rocker arm broke off and wedged in there somehow and is keeping two valves open? Just a guess.
IaGary
07-07-2006 21:01:49
That hydro 70 must be a woman if she got upset that easily.
Gary
IA Roy
07-07-2006 20:19:29
Be sure to check for water in oil and oil in water. Could be a head gasket blown between cylinders.
Allan In NE
07-07-2006 21:01:23
 Re: Oh, Oh. Made 'er Mad in reply to IA Roy, 07-07-2006 20:19:29
No bubbles in the radiator, no antifreeze in the oil. Piston tops and cylinders are clean as a whistle. No evidence of antifreeze leaking between the two.
I put air to #2 spark plug hole and it comes out #3. Air in #3 plug hole and it comes out #2.
Cracked head or gasket. Right?
Allan
JMS/MN
07-08-2006 09:06:05
 Re: Oh, Oh. Made 'er Mad in reply to Allan In NE, 07-07-2006 21:01:23
Hopefully- beats having holes in adjacent pistons. Course then the air would pressurize the crankcase and blow out the dipstick!
Keith-OR
07-07-2006 21:51:25
Allan, lets hope it is a head gasket. That would be my guess anyway.
Better start whispering when considering another project!!!!! :>)
Keith & Shawn
Robhkent
07-07-2006 19:13:36
Allan:
Sounds to me like I can here the sound of a nice 310D going in there.....
Rob
Allan In NE
07-07-2006 19:17:33
 Re: Oh, Oh. Made 'er Mad in reply to Robhkent, 07-07-2006 19:13:36
What are ya? A derned mind reader? :>)
I'm gonna pull the valve cover off and see if something is aray there. Strangest darned thing; was running fine one minute and the next it won't hardly pull itself.
Allan
806man
07-07-2006 19:09:08
I know how you feel....2 steps forward and 3 steps back!!! Remember this is no step for a stepper!!
Bob/wis
07-08-2006 09:46:03
 Re: Oh, Oh. Made 'er Mad in reply to 806man, 07-07-2006 19:09:08
Sounds like the head gasket is blowen between 2 and 3. There is a nice little narrow spot there that burns out. You will find the head might be warped along the length of it and warped across it. Take it to a machine shop if you do not have a precission straight edge to check it. Bob
