Tractor Talk Discussion Forum
stuck motor farmall h
Turke Bros. Far
07-09-2006 15:48:53
i just picked this h up and the motor is stuck. Nothing broken just pistons froze to the walls. Doesn't look bad from the lower end, there is some rust but not bad. everything is undone and the head is off. thought i would ask some of you grey haired farmall vetrans what is the best pentrating oil out there for the task. Thanks Dan Turke
BLW
07-10-2006 07:02:53
 Re: stuck motor farmall h in reply to Turke Bros. Farms, 07-09-2006 15:48:53
hey guys let me know if you get the H unstuck I have one been working on for 2 years-- pan off looks very good down there- cyl walls don"t even look that rusty- I got this second hand someone already tried the hammer bit---broke the rear piston, still didn"t budge-- have put some of the navy rust remover advertised on TV --this stuff worked on an old adjustable wrench all rusted for years but doesn"t work on the engine- so I"ll be very interested in the outcome-- Bruce
John T
07-09-2006 16:18:51
Dan, What I have used and poured in the cylinders n let set for days at a time is a Witches Brew of Diesel Fuel and Auto Tranny Fluid and Brake Fluid. Some use Turpentine and Coca Cola and other such concoctions but Brake n Tranny Fluid n Diesel has worked for me. It will be fun to hear what brews other have used, theres all sorts of home remedies n opinions on this one fer sure.
NOTE You may wanna start by first spraying PB Blaster and/or Kroil or Liquid Wrench etc all around the cylinder rims BEFORE you add the Witches Brew or whatever other Snake Oil you decide to use.
PS I qualify for your requirements, what lil hair I have left on the sides is silver n gray for sure lol
Let us know what you do n how it works
Ol John T
old
07-09-2006 16:14:02
Fill the cylinders with tranny fluid and let it sit a few days, then try to move them. If it doesn't move then refill the cylinders with tranny fluid and then add a table spoon of gas to the tranny fluid and lite it up and let if burn. If that doesn't work the only way will be a big hammer and a board that will just fit on top of the pistons. I have unlocked a good many engines and never even opened them up useing the tranny fluid so you may have took steps you didn't even need to take
