Tractor Talk Discussion Forum
O/T CYLINDER HONES
BLAND
07-10-2006 12:33:11
ANYONE KNOW WHERE A PERSON CAN GET A BALL TYPE FLEX HONE SMALL ENOUGH TO FIT A FARMALL CUB HAVING A HARD TIME WITH THIS
george md
07-10-2006 15:33:11
 Re: O/T CYLINDER HONES in reply to BLAND, 07-10-2006 12:33:11
Bland, Basically if your cylinder is in good enough
condition to hone with a dingle berry hone , it probably didn't need to be honed .Having owned a few ,found out that they are nearly worthless .For
the price of one of those you can buy a used AN
hone ( sunnen ) and it will true the cyl walls,
dingle berry hones and spring loaded ones will
not.
george
Greg_Ky
07-10-2006 15:04:26
Goodson
www.goodson.com
J Schwiebert
07-10-2006 12:59:26
I hope you are trying to remove much material with the ball type hone.
GA JACK
07-10-2006 12:44:16
CHECK MSC SUPPLY, 2005/2006 CATALOG PAGE # 880
MSC PHONE # 1 800 645 7270. good luck, jackie
