Tractor Talk Discussion Forum
Alomost saw my neighbor buy it
cj3b_jeep
07-10-2006 14:36:15
I was doing some trenching saturday and heard my neighbor down the hill, the obvious sounds of a stuck truck. After a few minutes, I decided to go down to see if he needed me to bring my tractor down to pull him out. I got on my 4 wheeler and headed down. I got there just in time to see him on his 9n yanking this truck. He had his 9n at about a 60 degree angle and got the truck out. He had a rake on the three point, had it raised all the way and had a chain hooked to it yanking the truck with it. After he parked the tractor, I explained a little bit about leverage to him and how many people have died doing what he did. I told him he needs some kind of drawbar for that kind of thing and to pull loads below the center of gravity. I'm not sure if he'll listen though, this is a guy who wrecked his 4 wheeler so many times he had to get rid of it to save himself more injury.
Chick
07-11-2006 00:17:47
 Re: Alomost saw my neighbor buy it in reply to cj3b_jeep, 07-10-2006 14:36:15
When I worked at the MF dealer, from time to time, we had to deal with a stuck clutch on old ford tractors. We would normally get a bush hog hooked up to it, crank it up, go out across the pasture behind us, and drop the cutter on a large ant hill. This worked everytime, the best that I remember. Well, my brother, in his infinite wisdom, found his old NAA with a stuck clutch. For some reason (I think it had something to do with a beer can), he got the tractor backed up to a pine tree, hooked a chain from the tree (about 24" in diameter), to the drawbar under the PTO. The tractor had old industrial tires on it, and he thought when it came to the end of the chain, the clutch would break loose, or the old tires would just spin. HA! Those old tires took hold, the clutch never slipped, and the tractor flipped over backwards! My brother had enough sense about him, to dive sideways off the tractor, and even at that, it tractor almost fell on top of him. It landed upside down, less that a foor from his shoulder, still running, with gasoline leaking all over the place out of the tank. He got it shutdown, and we got a front end loader to flip it back up right. Now, when he stops on of the old tractors, he jams a wooden wedge against the clutch pedal, so that the clutch plate will not stick to the pressure plate and flywheel.
vrickster
07-10-2006 16:30:07
 82 years young in reply to cj3b_jeep, 07-10-2006 14:36:15
My 82 year young rancher friend recalls many examples of tractor flip/roll over accidents. He told me to overcome this problem,
hook up from the front of the tractor and back out the stuck vehicle.
The flipping hazard is eliminated. This explanation may be easier to understand than center of gravity, leverage, etc. and is even safer, I think.
BobMo
07-10-2006 14:47:21
Has he been neutered? Might be a good idea..... .
cj3b_jeep
07-10-2006 14:48:45
 Re: Alomost saw my neighbor buy it in reply to BobMo, 07-10-2006 14:47:21
I think his wife would agree!
