Tractor Talk Discussion Forum
PTO shaft extension
vf4x
07-11-2006 16:30:00
What is the availability of a 1-3/8 to 1-3/8?
Fred Martin
07-12-2006 07:16:04
 Re: PTO shaft extension in reply to vf4x, 07-11-2006 16:30:00
I bought one the other day for the MF-35. The reason I bought it was that I had run the finish mower on the TO-20 with a over run clutch and it"s not needed on the 35...so the pto shaft was a bit short for the 35....and the 1 3/8" to 1 3/8" extension made it right. One thing I did notice about it was the fit on the tractor shaft was pretty sloppy...but after you rev it up,it centers up okay. I got mine at the local TSC store in Hillsboro, Ohio and paid about $21 for it. Fred OH
Bob
07-11-2006 22:30:13
Extensions are available. I need to check around a bit, to see where I have purchased them.
I will post back by tomorrow night.
Leroy
07-11-2006 17:44:48
Never heard of extension same size on each end, only 1 1/8" to 1 3/8" or 1 3/8" to 1 1/8" or 1 3/4" to 1 3/8" but never 1 3/8" to 1 3/8", have to agree with TSC
Keith-OR
07-12-2006 07:12:42
 Re: PTO shaft extension in reply to Leroy, 07-11-2006 17:44:48
Leroy, one needs a same size PTO extention if you are going to run a PTO hydraulic pump. I have one on my Oliver Super 77 for my FE loader. HTH
Keith & Shawn
Leroy
07-12-2006 16:17:35
 Re: PTO shaft extension in reply to Keith-OR, 07-12-2006 07:12:42
The only PTO powered hydrolic pumps I have ever seen fit on the orignal PTO shaft and would not work with an extension
Keith-OR
07-12-2006 19:06:03
 Re: PTO shaft extension in reply to Leroy, 07-12-2006 16:17:35
Leroy, all my tractors the pto shaft does not stickout far enough to accomatate either one of my PTO pumps(Prince and Parker)as the pumps are 6 inches wide at the input for pto.
If you have been following Allan in Neb, he is running extension for his pto pump on Farmall H for FE loader.
Keith & Shawn
Richard H.
07-11-2006 16:54:50
Got one the other day at TSC. $ 30 something I think.
vf4x
07-11-2006 17:40:03
 Re: PTO shaft extension in reply to Richard H., 07-11-2006 16:54:50
I thought they were available, but the local TSC acted completely unaware when I sent them a customer. Thanks for the reply.
IaGary
07-11-2006 16:33:15
Huh?
