Tractor Talk Discussion Forum
timing marks
redkev
07-11-2006 17:40:54
I need to know about the timing marks on my H, the crankpulley has one mark then two, where do I set the time,which line 1 or .2??
Keith-OR
07-11-2006 21:48:07
 Re: timing marks in reply to redkev, 07-11-2006 17:40:54
"The first notch on the pulley is timing advance (advance = happens first) so turn the crankshaft to the double set of notches that are about 1/8" apart. That is Top Dead Center (TDC). Aim the rotor to the 2 o"clock position & put it all together. The rotor turns clockwise. Firing order is 1-3-4-2.
Using a continuity indicator, rotate the distributor body clockwise so the points are closed and then slowly rotate the distributor back until the points just open. Lock the 2 capscrews down and you are good to go." By Wayne Swenson from Farmall Board
HTH...
Keith & Shawn
Turke Bros. Farms
07-11-2006 18:02:57
Please call me i have every tractor manual, i can help 810-434-0108 thanks
