Tractor Talk Discussion Forum
my truck, more info
Tim Shultz
07-13-2006 19:59:10
third party image
O.K, since ya' liked it so much her is a little more info.. it's a 73' F-250 highboy.. the last owner bought it new, and it was NEVER a daily driver.. he used it to pull grain wagons in the fall, and to plow snow in the winter.. also took it to some truck pulls.. pulled in the stock class, and NEVER placed lower than 4th.. it has the super low granny gear.. so it works pretty good for that he said. the bed is off of a newer truck, as you can see from the gas tank doors.. both of them in the bed are not hooked up.. only the one in the cab has a tank. it has a 360, and a C4 tranny. I added I cold air intake to it for a few more ponys. the paint I used was some cheaper paint from ACE hardware.. not sure what brand it is right off hand but it is at least 10 times better then the BPS that TSC sells.. I put 6, yes 6 coats of primer on it, the paint you see is only the first coat. it has tractor mufflers.. so it is pretty darn loud.. there might be louder trucks out there, but not legal ones.. ;-).. done got a verbal warning for this one.. so I try to take it easy around cops now.. as soon as I sell my second cutting alfalfa I am going to put in a crate motor.. any idea what would be the best way to go on that? if you have any other questions PLEASE ASK! I love talking about my truck.. love it to death.. :)
Tim Shultz
Jon Hagen
07-13-2006 20:26:16
 Re: my truck, more info in reply to Tim Shultz, 07-13-2006 19:59:10
Have fun with your toy,Tim. With a FE series 360 engine,I would bet you have a C6 (aluminum center case) ot atleast a FMX trans(iron center case section). I don't know that I have ever seen a bellhousing that would bolt a C4 trans to a FE engine. Several engine rebuilders make stroker FE engines in the 450-500 CI range. They are real torque monsters.
Tim Shultz
07-13-2006 20:13:34
and it ain't yellow becouse I am a deer man.. I go for allis and case.. ;-)
Tim Shultz
Don L C
07-14-2006 09:38:28
 Re: my truck, more info in reply to Tim Shultz, 07-13-2006 20:13:34
You need to be careful adding horsepower to the old girl.....you are going to start tearing up old tired parts.....
I have been building big engines all my life.....all new or rebuilt drive train is required and I dont mean stock parts.....
be careful not $$$$ sorry...Don
Tim Shultz
07-13-2006 20:02:23
third party image
Tim Shultz
07-13-2006 20:00:26
third party image
here is the 360, with cold air intake.
37 chief
07-13-2006 20:20:22
 Re: my truck, more info in reply to Tim Shultz, 07-13-2006 20:00:26
If it is running why do you want to replace the motor. One thing I learned a long time ago, is- if it works don't fix it. Stan
Badly Bent
07-14-2006 04:48:45
 Re: my truck, more info in reply to 37 chief, 07-13-2006 20:20:22
Amen, Stan. Amen...
