Tractor Talk Discussion Forum
E85 use in a WD 45 and small engines
JackT
07-14-2006 07:30:11
I'd like to save a few $$ by using E85 in my WD45 and single cylinder (Briggs) irrigation pumps. Can I just pour it in and head back to the field or can I expect engine problems down the road? Don't want to save a few $$ up front and have to rebuild the engines down the road.
Thanks!
Leland
07-14-2006 20:04:07
 Re: E85 use in a WD 45 and small engines in reply to JackT, 07-14-2006 07:30:11
Jack how do you figure your saving money ?? You will burn more E85 to produce the same power as if you were using gas ,belive me I know but if your E85 is not at least a 1.00 less than regular gas your just wasting your money but do what you want but my truck used about 65.00 worth of E85 per week compared to about 45-50.00 worth of gas so this stuff is not worth it to me .
Hermit
07-14-2006 19:11:56
The gasket, seal and fuel line deterioration is more of problem with biodiesel especially components with nitrile rubber. Professors from Iowa State University and the University of Missouri has a nice study concerning biodiesel and it's effects on vehicles (available on the 'net).
If you want to see the fuel consumption difference between regular lead-free and E-85 just go to the Ford dealership and look at the window sticker on a flex-fuel F-150. You'll see 25-30% less mpg with E-85.
Brazil is not a good example for the use of ethanol, contrary to popular news programs. Facts are presented but not all the facts. Brazil got off foreign imports not through ethanol but by expanding their own off-shore oil rigs and increasing output. The Brazilian government never required anything close to an E-85 type fuel. In fact, last year the Brazilian government reduced the amount of ethanol required in fuel from 25% to 20% because the farmers are not selling their sugar cane(the raw source for ethanol) to the ethanol plants but to the more profitable candy dealers. And now, the government wants to clear more rain forest to make farmland to grow more sugar cane and support the ethanol market. Environmentalists are opposing that and Brazil may have to start importing oil again. And look at the problems when depending on mother nature. In 2000, Brazil had a big drought that destroyed much of their sugar cane crop. They had to import ethanol from the U.S. (ADM to be exact), the second largest producer of ethanol.
There's more but the bottom line is marketing. The farmers and distillers have every right to make, and convince others, to buy their product. It's called capitalism. And those folks can try to have the government mandate E-85. Once that's done, the market will follow. Look what happened with High Definition TV. A absolutely great business scheme. It's not really needed or necessary but now it's mandated.
And remember, if E-85 is mandated the oil imports won't decrease. That's because crude oil is made into, and part of, many other products from medicines to asphalt to jet fuel. Since we're not exporting any of the other crude oil products, we'll still need to import the same amount of oil, if not more, for all those other-than-gasoline products.
Minn.norske
07-14-2006 18:34:14
I have been mixing E-85 & gas 50/50 all summer in my golf car,lawn mower, a vac that I use for mowing,& in my antique tractors with no problems with any of them. Minn. Norske
Minn.norske
07-14-2006 18:33:26
dej(JED)
07-14-2006 11:23:23
How efficient do you think these old distillate burners were on any fuel? These old tractors will burn aboout anything once they are hot. I have run 80% blends of methanol,ethanol,ethyl tertiary butyl ethers, methyl tertiary butyl ethers, etc. for years in a Farmall M, H,C, B; AC WD, 45 B, C; JD A, B , 70,etc. I saw no damage or little if any change in power.
Gerald J.
07-14-2006 09:58:56
Those who claim it takes more fuel than ethanol supplies have an agenda to kill ethanol, often paid for by big oil. And they base their claims on perceptions of farming and ethanol production based on 30 year old technology that isn't being used today. We sell corn from the field at $2.00 to 2.50 a bushel and we don't go broke rapidly. The best ethanol plants make 2.9 gallons of ethanol per bushel of corn, and have some waste heat to use warming green houses for vegitable production and process heat for other projects plus the distiller's grain is as fine a cattle feed as the raw corn that went into the ethanol plant.
The number I've seen in my research on conversions is that E85 needs 43% greater volume. So that means larger jets in the carburetor or fuel injectors with larger volume ratings. Beyond the gasket question, in the none computer engine, it means tuning the carburetor for the E85, then back again for regular gasoline. This issue is so complex (NOT!!) that it was standard issue for Model T and A Ford cars where the main jet was adjustable from the driver's position specifically to allow the use of straight ethanol or gasoline nearly a century ago.
I think the key to using E85 in a conversion is to monitor the exhaust gas temperature and watch for the high temperature of lean running, then there shouldn't be burned pistons or valves.
The low compression engine won't make great use of ethanol unless its run a bit on the lean side and maybe with more advanced timing. One Volvo turbo engine actually raises the boost to effectively increase the compression ratio when it senses lots of ethanol in the fuel and does make better use of E85. That higher octane does allow E85 to run some leaner than gasoline partly compensating for the need for greater volume.
A computerized fuel injection engine may well run E85 with no modifications if not run at full power. Or if the factory injectors are bit on the large side.
There may be some concerns with in line fuel pumps, gaskets, and tank flash overs, though E10 should have shown up gasket and tank cleanliness issues already.
Gerald J.
RustyFarmall
07-14-2006 12:20:13
 Re: E85 use in a WD 45 and small engines in reply to Gerald J., 07-14-2006 09:58:56
Thank you for that info Gerald. It is all true, and I might add that there is no part in a tractor carburetor that could ever possibly be destroyed by the use of ethanol. Somebody mentioned that the gasket would be destroyed, wich is next to impossible. Afterall, those gaskets are made of paper, if ethanol could destroy them, then gasoline would have the same effect.
Dental Trivia
07-14-2006 08:35:21
Yesterday, while waiting at the dentist office, I was reading an article on alternative fuels in a Popular Science(?) magazine. According to their studies, it takes 57% more E85 to achieve the same results with a gasoline engine. Their example was: If you can travel 20 miles on a gallon of gasoline...with E85, it would take 1.57 gallons to travel the same distance.
Or if you apply that to a tractor: If you are burning 4 gallons per hour...with E85 it would increase to 6.28 gph.
I don't know if I can believe that, but since I've never tried E85, I have nothing to base a opinion on.
chuck42
07-14-2006 08:48:06
 Re: E85 use in a WD 45 and small engines in reply to Dental Trivia, 07-14-2006 08:35:21
I have heard similar numbers. Also heard it takes more Oil to produce a gallon of E85 than it replaces. Ie use up 1.15 gallons of gas or equivalent (diesel) for 1 gallon of E85. Couple those together and it would appear we are going backwards.
Finally I've been hearing tales(no facts yet) of E85 distroying engines not built for it. The two I've heard of are small (piper) planes and snowmobiles. May apply to generators/pumps/chainsaws etc...
Has anyone actual experience data?
JMS/MN
07-14-2006 23:26:00
 Re: E85 use in a WD 45 and small engines in reply to chuck42, 07-14-2006 08:48:06
Heard, heard, heard, no facts. Typical coffee shop bs. Studies showing ethanol production requiring more energy to produce than what is obtained have been proven wrong. E85 destroying engines not built for it? What part of that don't you understand!!!!.Run diesel in your gas car and see what happens. Our '03 Dodge van runs 21.2 mpg on gas, 19.7 on E85. Gas is $2.99, E85 is $2.13. No soldiers die protecting our corn fields.
dhermescc
07-14-2006 09:50:56
Depends on whom you ask. If alcohol production created a net loss in fuel then I would like for someone to explain how Brazil has eliminated their dependence on foreign oil.
As for fuel consumption, E85 contains less energy then 87-octane fuel. But with proper engine design it can be nearly as efficient. An E85 engine can (most don’t) operate on a much higher compression ratio then typical gas engines and can be nearly as fuel-efficient.
Cars that have been adapted to run E85 (especially carbed vehicles) get terrible fuel mileage. Cars like the Ford Taurus that come from the factory with flex fuel in mind get about 75% to 90% of fuel mileage while running on E85 as appose to 87 octane gas. The thing to remember is that this system is an "add on" to a conventional gas engine and not a ground up design to run on E85. In the coming years I expect that to change. Much like the early emissions equipment in the 70s and early 80s decreased fuel mileage and power while current designs incorporate emissions standards and have greatly improved performance.
As for using E85 in a WD 45, unless it has a distillant set up I wouldn't try it, you'll burn more fuel and not come out ahead.
Gerald J.
07-14-2006 20:54:50
 Re: E85 use in a WD 45 and small engines in reply to dhermescc, 07-14-2006 09:50:56
About 2000 U Texas participated in a college contest to make an E-85 vehicle. They changed the injectors for larger injectors, moved the fuel pump out of the gas tank, added better fire flash suppression to the gas tank filler, and changed some gaskets. They didn't change or chip the computer. The computer controlled the larger injectors just fine.
The E-85 option isn't an addition to most vehicles, its just using different parts that had to be there anyway. I don't believe those spokesmen who talk about ethanol sensors for the fuel line, I think the sensor used is the standard oxygen sensor in the exhaust pipe just like burning any other fuel. The computer takes care of the different mixture.
Burning ethanol in intern combustion engines isn't rocket science. Ford's models A and T did it when they were new. Took a driver adjusted mixture knob.
Gerald J.
jal-SD
07-14-2006 07:54:40
Don't use E-85 in older engines, the carb gaskets won't won't stand up to that much alcohol, they are not designed to withstand the chemical composition. It isn't recommended to use even E-10 in small engines, but you can get by using E-10 in your WD45. I use in in my H all the time in the winter, it eliminates the need for heet in the gas. It will disolve all the varnishes that you have in your tank & you'll clean the carb a couple of times when you first start to use it. (My $0.02 worth. jal-SD)
jddriver
07-14-2006 14:51:09
 Re: E85 use in a WD 45 and small engines in reply to jal-SD, 07-14-2006 07:54:40
I would like to see yout proof regaurding your statements,Steve
John (MO)
07-14-2006 07:59:03
I have run a few tanks of E85 through a WD with no problems at all. Couldn't tell the difference. I've used E10 for several years.
