Tractor Talk Discussion Forum
Thread inserts?
John in Ct
07-16-2006 18:22:47
I have been using Helicoils with good results but always am looking to do better. I have heard that there are better options out there. Does anyone know what are they called? How are they installed? Thanks!!
Glen in TX
07-16-2006 20:03:26
 Re: Thread inserts? in reply to John in Ct, 07-16-2006 18:22:47
McMaster Carr & MSC sell some different ones also:
mcmaster.com
mscdirect.com
Davis In SC
07-16-2006 19:47:22
If there is room to spare, around the hole, I like the solid Inserts. You just drill & tap a larger hole, & screw the insert in. For instance, for a 1/2-13 thread, the insert is 3/4-10. I get mine at Travers Tool. On some aluminum tools I build, I use these inserts, when I build them, much stronger than running bolts directly into the aluminum.
MikeinKy
07-16-2006 18:47:44
I have been using a similar insert called Recoil, for a while. I like the installation tools a little better than Helicoils. I also have another one that I can't remember the name of, it is thicker and you drill a larger hole. It is good if you have to destroy the original hole. I got them from Lawson company.
