Tractor Talk Discussion Forum
Wisconsin v4 fuel pump leak
paul
07-17-2006 18:42:02
Got 10 acres of oats left to cut, & the fuel pump is running out fuel in a constant stream out the 'leak holes'. Obviously the diaphram is rotted through.
It's a round pump, lever activated, even has a manual finger pumper on it.
I took it apart, & the diaphram is connected to the lever in the middle of the pot metal. How do I disconnect the diaphram from the lever? Lever is all riveted togother so it won't follow through after the diaphram; they must disconnect somehow but no room to get in & do so?
Then, will I even be able to get a diaphram any more for this old cast iron engine? It goes way back, actually dad got it off an old Woods corn picker, put it on the swather.
Magneto; no charging system on this, tho I do have a 6v battery riding along to run the starter a few times. So, electric conversion would be messy, I'd just like to figure out the diaphram pump?
--->Paul
paul
07-19-2006 00:04:24
 Thanks in reply to paul, 07-17-2006 18:42:02
Went to the Carquest store this morning (slightly better stock than the local NAPA; we use both 'round here).
Put both halves of the fuel pump on the counter, & the nameplate from the Wisconsin engine - wanted all numbers available to track the old thing down.
He looked & said, "I sold it yesterday afternoon, sorry, but another will be in tomorrow by 7:30."
They actually stock them, not a special order!
Tho he looked it up to make sure, and couldn't find my exact engine referenced. I have an F, the E & H and many others use the fuel pump, so it should work.
--->Paul
Glen in TX
07-17-2006 22:44:27
 Re: Wisconsin v4 fuel pump leak in reply to paul, 07-17-2006 18:42:02
Like said push it down against spring underneath to unhook it from the lever. Same fuel pump kit should fit all the Wisc. V4 pumps but the larger V461 & V465 had a different pump. Inlet and outlet are at different angles. Try NAPA or a small engine repair shop. or...
continentalengines.com
planopower.com
tulsaenginewarehouse.com
wisconsinmotors.com
Bus Driver
07-17-2006 18:54:30
It has been a few years, but I bought my last pump for one of those engines at NAPA. Bobcat dealer might have some parts as some of their loaders used the Wisconsin.
Coloken
07-17-2006 18:53:29
No guarantees.... Push in and try to un-hook from the lever. It should unhook.
Most of these old pumps were a lot alike. Same size diaphram. You may have to re-rivet the center on a new diaphram I've been know to buy a new pump of wrong fit, but same diameter and tear it down for parts. {Kaiser/Frazer)
