Tractor Talk Discussion Forum
how could it run
joemn
07-18-2006 19:50:12
doing an out of frame overhaul on my b275. it has a bd144 diesel engine. got my crank back and went to line up all the gears and found the pump gear mark to be about 150 degrees off the idler gear mark when aligned properly with the crank. also found the pump was set on 0 the book says 20 degrees btdc is optimal. what should i do and how did the pump get so far out of time and still run. it did smoke and had a miss before i tore it apart
