Tractor Talk Discussion Forum
6 Volt Optima Battery
48C-MAN
07-19-2006 12:15:30
Will an Optima 6 volt battery fit into a farmall C battery box. Nearing completion of resoration and did not like how the battery acid from the old battery leaked.
Steven@ND
07-19-2006 18:26:06
 Re: 6 Volt Optima Battery in reply to 48C-MAN, 07-19-2006 12:15:30
Size Category: 6V Medium
10 x 3.5 x 7.8"
Height includes 1" terminals 18.4 lbs
jeffcat
07-19-2006 17:48:18
I bought one for my dad a couple of years ago. They are pretty small and should fit. The old sixes are a class or case one. I think that is correct. You DON"T want a forklift six volt cause they are a number two. Are about 1/4 inch wider and about 3/8 taller. If you find your local Interstate battery warehouse you can get some good deals there. Do find it! Jeffcat
Mike M
07-19-2006 12:58:50
Maybe try a post over at the John Deere board and look for FIT he has used those in a Case VAC and maybe others.Maybe he can tell you what size they measure.
