Tractor Talk Discussion Forum
O.T. Gas man's nightmare
Rod in Smiths F
07-19-2006 16:49:54
The deal with my wife was that she would get a high-end kitchen in return for giving up her house in town.
The gas guy and his helper arrived today to run the line for the new DCS range. In an old stone house nothing is easy but things went normally until they drilled a hole though the west wall. Or somewhere. The 32" drill didn't make it through, and they had started in a cavity 18" deep. Much perturbation and attempted excavations from both sides came to naught until I grabbed an old ground rod and sledge and determined to bludgeon my way through the wall. Nearly gave the assistant a third nostril as I pushed the 6' ground rod through some mortar and up to the hilt.
54" of stone wall. Why would anyone built one like that? the time of construction in the late 1830's. as anyone else run into a really thick wall in a house?
NC Wayne
07-19-2006 20:06:46
 Re: O.T. Gas man's nightmare in reply to Rod in Smiths Falls, ON, , 07-19-2006 16:49:54
You said the house was built in the 1830's making it 170+ years old. You answered your own question, what house built nowdays is gonna be around in 170+ years? They built things to last back then, nowdays we live in a society where everything is made to be disposable..... ..
old
07-19-2006 19:58:31
Sounds like a house my dad told me stroys about. If was his garndfathers house in MN. It had double stone walls with a gap between the walls filled with saw dust. From what he says about it the house was easy to heat in the winter and was cool in the summer
Hermit
07-19-2006 19:00:59
Sounds like you hit the base of an old fireplace.
07-19-2006 19:17:34
 Re: O.T. Gas man's nightmare in reply to Hermit, 07-19-2006 19:00:59
That sounds reasonable. Below the fissure where we started drilling the parging is crumbly and shows a lot of old brick mixed in with the sandstone.
But the 54" section is the thin part of the wall, the south-west corner. After five feet it juts back at least another three feet into the basement, and still no fireplace. A chimney for a stove and a furnace goes up through the middle of the end wall. An identical chimney at the other end accomodates another stove pipe.
An architect friend suggested they might have walled up a well with the extra stone, though there is a cistern at the other end of the house.
mjbrown
07-19-2006 18:12:18
Mans house is his castle. Someone took it literaly. Any sign of a moat? Drawbridge?
Yugrotcart
07-19-2006 18:07:41
Rod,
I have a 150 year old stone house in Guelph. It is made of limestone blocks, but no were near as thick as your walls, maybe about 2 ft. I replace 4 of the main windows last fall, and believe it or not, all 4 were identical in size. They don't build houses like this one anymore..... ...
07-19-2006 19:05:03
 Re: O.T. Gas man's nightmare in reply to Yugrotcart, 07-19-2006 18:07:41
Yes, I too replaced the main windows and their frames, two summers ago. In the case of our house the same guy had obviously done the two front windows, and another made the same mistake on both of the rear portals, requiring an additional 2" header installed over the main one. The window sizes were identical, though. Last summer involved replacing the upstairs windows and redoing the four dormers.
I'm gutting the rest of the upstairs this summer. It doesn't make sense to go this far without putting a proper vapour barrier and insulation mat around the entire compartment. So it takes another year? I'm retired.
Bill of TN
07-19-2006 18:10:49
They sure don't build them like they used too!
