Tractor Talk Discussion Forum
What do I have here
Errin OH
07-19-2006 21:26:50
third party image
I planted a sorgum/sudan hybrid for cattle feed. In the lower areas (where pooling could occur) I have the stuff on the left. It is a ridged triangular stalk to a pointy seed head. The thin leafy part is deep V and ridged as well. The right appears to be (I hope) the crop. About pencil size stalk with nice broad leafs. In the better drain areas it about 5' tall down to about 2' where the other stuff is prevalent. My concern is I was told not to cut it under 20" due to harming the cattle (acid content). But the stuff on the left is only about a foot to 15" tall and turning yellow. What is it? Could excess moisture cause the seed to mutate? Bad / contaminated seed. This field was pretty clean, grain crop last year. So I am pretty sure it was planted as I haven't found any thing like it out side the planted area. Plus I may have planted it a tad to deep.
Errin OH
07-20-2006 05:53:21
 Re: What do I have here in reply to Errin OH, 07-19-2006 21:26:50
That sure is what it looks like. But I don't quite understand how I got so much of it if it really is not a seeding plant. I have been working this field for 4 years now. First year we took grass hay off it (aquired it to late to plant). Did corn the second, beans the third, and this year the sorgum hybird. While I hadn't got a 100% control on weeds and grass on it just yet, I am 99.99% positive this stuff wasn't present prior to planting the hybird. Plus to my knowledge, it isn't growing anywhere else around here (any of the fields around it).
John (C-IL)
07-20-2006 05:51:09
You can kill yellow nutsedge with Basagran and not hurt your crop. Please consult your local crop specialist for labeling and application details.
hillbillyOH
07-20-2006 04:06:39
That would be yellow nutsedge, my friend. It likes to grow in drainage areas.
Don-Wi
07-20-2006 00:12:27
I have always been told by my dad that if it's that short after a frost to just leave it in the feild, but otherwise it'll be fine.
What are you planning to do with it? If you are going to chop it and put it in a silo, I wouldn't loose any sleep over putting the short stuff up with the rest.
As far as the grass, it ain't what you planted.
Donovan from Wisconsin
no.2
07-19-2006 23:59:05
It might be yellow nutsedge. If it is it will take a high rate of round-up to kill it.
oliver fan
07-19-2006 21:35:17
I don't know the correct name for it. but I have always called it nut grass. You will see a nut like seed on the root.
It will grow wild in wet areas. It has nothing to do with your sorgum/sudan grass. It can be hard to kill, but Roundup will kill it, along with everything else.
