Tractor Talk Discussion Forum
Farmall Model B Serial Number
Kermit Vetter
07-21-2006 19:22:26
I have a Farmall model B with the serial Number FAB 198198 which is diplayed both on the tag on the seat bracket and on the engine block. According to S/N guides this tractor should have been manufactured in 1947. However this tractor is equiped with an IH magneto. I was informed that Farmall stopped equiping Model B's with magnetos in 1945 and used distributor ignition after that. What is correct? Is it really a 1947 model or and older model?
gene bender
07-22-2006 04:50:47
 Re: Farmall Model B Serial Number in reply to Kermit Vetter, 07-21-2006 19:22:26
the mag is correct no dist till 49 or so
Kermit Vetter
07-24-2006 21:50:45
 Re: Farmall Model B Serial Number in reply to gene bender, 07-22-2006 04:50:47
Thanks, I read in the service manual that they had magnetos but later had changed to Dist. Give service info for both systems.
Kermit
Charles McNelly III
07-21-2006 19:50:58
Hi Kermit, You were told wrong,ALL Farmall B's came with the mag. I too have a 47 model B. The model A's switched to a distributor in 52. Your tractor was one of the last B's made on Chicago.
There fun tractors to play around on.
Charles
Kermit Vetter
07-24-2006 21:53:54
 Re: Farmall Model B Serial Number in reply to Charles McNelly III, 07-21-2006 19:50:58
Thanks, I read in the service manual that the B had magnetos but later had Distributors. The manual gives service info on both systems.
According to Serial number guides, 1947 must have been the last year that the B was manufactured.
Kermit
Ford 312
07-21-2006 19:47:45
Dad owned a 1948 C Farmall and I am reasonbly sure it had a magneto. Maybe IH gave the customer a choice.
