Tractor Talk Discussion Forum
JD50 runs on one cylinder unless choked
guikema
07-22-2006 18:54:11
My JD 50 only fires on one cylinder unless I choke it then it fires on both. Obviously ther is good spark on both. When I choke it both fire. What do I need to check and how?
Gene Davis (Ga.)
07-22-2006 19:15:27
 Re: JD50 runs on one cylinder unless choked in reply to guikema, 07-22-2006 18:54:11
The reason the tractor only runs on both sides when you choke it is because only one side of the carburetor is feeding fuel through the jets. TRhe number series,(50,60,70) John Deere Waterloo tractors were the first to be equipped with the "Duplex" carburetor which is actually two seperate carburetion systems feeding from one fuel bowl. Think of it as a 2 barrel carburetor like on an automobile. The carburetoe probably needs cleaning and then tuning. Was working for JD when they brought out this systyem, and was actually a big improvement over the old single barrel carburetor system. It could be adjusted better and gave more fuel economy over the old system even though the old one barrel system had an economizer sysytem in it. The way to tune this tractor is to short out one spark plug wire and adjust the misture for the other cylinder, then restore the spark to the one you shorted and do the same procedure for the other cylinder, then set your idle speed screw.
