Tractor Talk Discussion Forum
How do these tractors compare?
Bill A
07-25-2006 16:32:33
I need to buy a 40-50 horse tractor for general use like brush hogging, disking, etc. I have been looking at old Massey tractors like the 150, 165, 245, etc. How do the same vintage John Deere and Ford tractors compare? Like the 2040, 2240, 2440, JDs or the Ford 3000 series? The only tractor I am currently familiar with is a MF135 that I have borrowed. Thanks for the opinions....
Carp
07-26-2006 09:12:35
 Re: How do these tractors compare? in reply to Bill A, 07-25-2006 16:32:33
If I had $8,500 on a good tractor, I would get a Foor 4600. Best all around tractor for that size that I have been around.
JDknut
07-26-2006 03:51:21
All other things being equal, the best tractor ever made in that size range is the Massey 165. But if you can find a good deal on a decent Ford or Deere similarly sized, you will be doing OK.
Matt Smith
07-25-2006 18:34:15
Where are you located? I know of a Massey Ferguson 250 in good shape for $6,000. I've run the tractor before and it's strong.
Bill A
07-26-2006 06:18:25
 Re: How do these tractors compare? in reply to Matt Smith, 07-25-2006 18:34:15
I am in Oklahoma.
Dachshund
07-25-2006 17:13:33
You will be happy with either choice! The JD will run a bit higher and parts are more expensive, but both of them are good machines. Good luck!
tmay
07-25-2006 17:09:04
I have both JD 1020 and Massey 135. I like both of them. The JD has about 3 more hp but the massey will outpull it. JD has power steering and hydralic brakes massey does not All in what you like. I believe you will be ok with either one.Stay safe
Bill A
07-25-2006 16:44:41
I would like to stay under $8500. A local used dealer has a MF-245 and a JD-2040 for the same price. The tractors are comparable in horsepower, size and condition. I am new to tractors. How do these tractors compare?
GRJ
07-25-2006 16:37:43
The old saying,that you get what you pay for, probably applies here. The Massey's & Fords will be less money than the Deere's.Depends on what you want & how much money you have.
