Tractor Talk Discussion Forum
6060 allis timing advance or retart
Kraiger
07-25-2006 19:09:50
I rebuilt a motor on a 6060 allis diesel, all new injectors, I got it running worked it out but it still starts like crap. I have no dyno so it is hard to set the timing. I static times it, will advancing or retarding the timing make a diesel start better?
Hurst
07-25-2006 20:04:49
 Re: 6060 allis timing advance or retart in reply to Kraiger, 07-25-2006 19:09:50
Can you not set the pump timing with the front pully with #1 at top dead center and then line up the 2 marks in the timing window on the pump (if a roosa master/staydine) and bolt the gear in place again? that is how it was on my 7000 with a 301, I am guessing this has the 200 cu in motor? I had to take the front timing adaptor plate off of my 7000 and I timed it like this and it worked just fine. I believe advancing helps if it is not advanced too much (too much advance should cause it to hardly run though I think). The pumps had an automatic advance on them if a roosa master/staydine. My 7000 is only set for soemthing like 18 degrees before top dead center I believe and it has the automatic advance. The 190xt though, according to the I&T manual is supposed to be set to somthing like 28 or 29 degrees before top dead center, but it doesn't have teh automatic advance on it. Good luck. I hope that information is pretty correct. An I&T manual will show you how to time it. I never heard of hooking up to a dynometer, but I haven't been around tractors as long as a lot of you all have.
Hurst
kraiger
07-26-2006 03:13:02
 Re: 6060 allis timing advance or retart in reply to Hurst, 07-25-2006 20:04:49
Thanks, I will check
