Tractor Talk Discussion Forum
O/T: 2000 Chevy 3500 Flasher Problem
rkn
07-27-2006 12:21:56
I am having trouble with my warning flashers.
Turn signals work fine and I have checked fuses
on the hazard/brake circuit. Brake lights work
also. I have been all over this truck looking for the flasher. Found one under the dash for
the turn signals. Changed it out for new one
and I have the same thing. Is there another flasher hiding somewhere? All my other
vehicles have two flashers. Any suggestions
will be appreiciated. I need help on this
because I have to get inspection done.
thanks
RusselAZ
07-27-2006 21:11:07
 Re: O/T: 2000 Chevy 3500 Flasher Problem in reply to rkn, 07-27-2006 12:21:56
Turn signal flasher and Hazard flasher is the same. If the hazards don't work it will need a new multifunction switch. On a chevy this will cost quite a bit. When you get the new one you will see why. A switch for a vehicle with cruise runs about $350 and takes all of 3 hours to change.
USA
07-27-2006 19:33:23
Do you have the owners manual? It should tell where it is. Might be able to find one on the web. "Sometimes" if you have bad wiring to your trailer it can affect the hazard flashers. Keep looking, it's in there somewhere.
