Tractor Talk Discussion Forum
Oh, This Is Just Great! :(
Allan In NE
07-31-2006 13:20:59
If it ain't one thing, it's another.
Just spent this side of $700 getting this head redone. New everything down to and including the darned keepers.
Start it up and it runs perfect until it starts to warm up. In about a minte, it goes to missing on one cylinder, then two, then three, then she just flat dies.
Doggone valves are hanging open in the guides. Head has gotta come back off of there.
This just about makes my day. :>(
Allan
third party image
Rauville
08-01-2006 05:26:15
 Re: Oh, This Is Just Great! :( in reply to Allan In NE, 07-31-2006 13:20:59
Do those engines use sodium filled valves on the exhausts? Did they get replaced?
I guess I always thought that bronze guides were the best for heat dispersing.
Good Luck w/ your projects.
msb
07-31-2006 20:41:07
Did they knurl the guides? FIL used to be service manager at a Chevrolet dealership for about 30 years.He alway insisted the valve guides be knurled
Hobo,NC
07-31-2006 18:39:25
Guess ya gonna have to pull the head. it’s the machine shops problem now. ‘bout the only thing that would be a fought on your end is if their were no oil on the stems to cool the valve stem. Oil does not have to lube the guide but has to take a way heat that is generated in the combustion chamber and transmitted to the vale and stem. Once a valve sticks cause of a clearance issue no amount of oil is gonna relive it. Its gonna have to have to be sized correct or you will fight it till he!! free'izz over.
the tractor vet
07-31-2006 18:13:07
Now that is a new one on me as i have never heard of such a thing . Ya sure that the timming is correct , ya running 93 octain gas in her??? Ya don't have the thermostat in backwards ???? I have done somany 6 cylinder gassers that i can do then in my sleep. I PLUM DON"T KNOW ON THIS ONE YOUR ON YOUR OWEN .
cadet trooper
07-31-2006 16:19:46
Well, if it was around here I"d say it got too hot. Whew! 100degrees today, at least you didn"t break or been sumpin I hope.CT
BobHnwOh
07-31-2006 14:46:05
Allan,with engine runnin,spray Marvel Mystery oil on the valve stem above the guides,then add about a pint to the crankcase,Bob.
Nebraska Cowman
07-31-2006 14:33:31
Well hey, I'm just glad to see you fightn' sompin besides that darn fire :)
TGIN
07-31-2006 13:41:59
Around here it seems like the busy season is when I get to do things like that over !! During the off season that would`nt happen .
RustyFarmall
07-31-2006 13:37:31
I had that happen on a car engine several years ago. Don't remember exactly what we did, but we didn't tear it back down. Some kind of oil additive maybe?
RustyFarmall
07-31-2006 13:39:03
 Re: Oh, This Is Just Great! :( in reply to RustyFarmall, 07-31-2006 13:37:31
Does it have those little umbrellas on the valve stems? Maybe pry them up and squirt some oil in underneath them?
Allan In NE
07-31-2006 13:49:08
 Re: Oh, This Is Just Great! :( in reply to RustyFarmall, 07-31-2006 13:39:03
Yeah,
Never even thought of it, but I should have insisted that he use cast iron guides.
Had it happen to me once before also. Darned brass guides just seem to take a little more oil clearance.
I'll call that machine shop and see what he says.
Allan
old
07-31-2006 14:11:33
 Re: Oh, This Is Just Great! :( in reply to Allan In NE, 07-31-2006 13:49:08
Instead of oil you might try some tranny fluid since its a lot thinner and seems to make stuck thing come unstuck. Just another idea to run with
MN Bob
07-31-2006 15:14:51
 Re: Oh, This Is Just Great! :( in reply to old, 07-31-2006 14:11:33
Well Allan, like you have said many times, (at least once lol), I just need something to wrench on. lol again; Happy to see you had time to spend in the shop. Bob
