Tractor Talk Discussion Forum
Cracked Block
Bill Caldwell
07-31-2006 21:19:07
SIRS,
1996 Jeep Cherokee 6 clyinder inline . Block Is cracked on manifold side .I can't get to the crack to stick weld it. Without pullin' the engine, I can't get to it good enough to try J B weld. Which of the compounds that can be poured in the radiator have You had the best luck with sealin' tractor blocks .Tryin' to keep this one runnin'(over 200,000 miles) ,My daughters College car,30 miles each way. Engines not cracked on inside ,leaks on outside .
Thank You,
Bill
the tractor vet
07-31-2006 21:38:12
 Re: Cracked Block in reply to Bill Caldwell, 07-31-2006 21:19:07
I have had good luck with K&R block sealer but you have to drain and flush the system with a cleaner a couple times remove the thermostat fill with clean water pour the stuff in a hot engine and run for about thirty min. then drain and let set for 24 hours then if it worked you can refill with antifreeze and good to go.
37 chief
07-31-2006 21:27:28
I have had real good success with a product Napa sells called Irontite. Stan
