Tractor Talk Discussion Forum
john deere 8th geer
mss3020
08-02-2006 14:22:02
On my J.D. 3020 when I try to shift into 8th gear or road gear it wont go or will go sometimes then jump out to a lower gear. Is there an adjustment I can make to clear this up?
Thanks
Scott
Glen in TX
08-02-2006 18:46:14
 Re: john deere 8th geer in reply to mss3020, 08-02-2006 14:22:02
It will cover adjustments in a (Primedia) I&T shop manual for 3020 or simular tractors or a 3020 JD SM service manual. Adjust the linkage first and inspect pins, rods, bushings & shift quadrant on dash for wear. Also check the shifter arms on side of trans for wear first too. Then after adjusting or replacing those parts doesn't fix it you can wonder about other problems inside. Can also view the parts catalog online at JD Parts. http://jdparts.deere.com
