Tractor Talk Discussion Forum
MF 35 clutch pedal adustment
NCCub
08-02-2006 17:13:08
Any tips for adjusting the clutch pedal? I have a lot of play when I start to press the pedal down. I took the bottom cover off, looks like a plate goes against some hex head bolt, tough to get to, do I just break the hex head bolts loose and back them out?
Thanks,
Kerry
nhboyd
08-02-2006 18:57:15
 Re: MF 35 clutch pedal adustment in reply to NCCub, 08-02-2006 17:13:08
the clutch pedal is clamped to a shaft. loosen the bolt so the shaft will turn in the pedal. there is a hole in end of sfaft. turn the shaft until you get 1 1/2 in. of free travel. make sure you tighten bolt tight.
