Tractor Talk Discussion Forum
IH 574 warning
R. John Johnson
08-02-2006 22:41:41
In my post below I stated the steering wheel came off the tractor. We owned a 574 in the '70s and had the same thing happen. In both cases the cap on the steering wheel became damaged and was removed. Both tractors sat outside. Water will pool in the center of the steering wheel and there is a path for it to get to the top of the steering motor. A retaining ring holding the input shaft into the motor rusts away, allowing the steering wheel and shaft to come out of the motor. It's been almost 30 years since ours failed, and I haven't seen the neighbor's so my description may be a little off. Anyone out there with an IH utility tractor of this series, if the cap on your steering wheel is gone, check that ring and replace that cap.
John
mike,tnn
08-03-2006 06:29:39
 Re: IH 574 warning in reply to R. John Johnson, 08-02-2006 22:41:41
When people neglect there equipment and don't maintain it properly this is what happens.
JDknut
08-03-2006 03:53:47
My old White used to have a similar problem but it was a little different in that while the steering wheel never came off, whenever it got colder than about 20 degrees, the water froze in the hub so you couldn't turn the steering wheel. You had to go to Blowtorch City (carefully) to thaw it enough to use it.
