Tractor Talk Discussion Forum
Hey Old...
hillbillyOH
08-03-2006 12:21:02
You recommend transmission fluid as a way of breaking free a stuck engine.
Here's my question: does the fluid then need to be removed once things come loose? Or can you go ahead and kick the engine over and see what happens?
Thanks in advance.
old
08-03-2006 13:14:07
 Re: Hey Old... in reply to hillbillyOH, 08-03-2006 12:21:02
You can try to pop it free with the plugs in but as soon as it moves any you then need to pull the plugs or you can bend or brake a rod because of hyd lock. Also if you don't want a mess you need to hang a rag etc on the side or it will shoot the tranny fluid all over. I've done it a few times and wasn't thinking and got a shower in tranny fuid which is ok but sure isn't all that nice either. Did that one time on an H I was playing with and had the starter hooked up so that there was no switch and I would just put the cable on the battery and it popped loose and shot tranny fluid all over me from head to foot. But at least I was driveing it an hour later so the shower wasn't all that bad for what the out come was.
hillbillyOH
08-03-2006 18:35:06
 Re: Hey Old... in reply to old, 08-03-2006 13:14:07
Thanks... I did have WD-40 in the cylinders, but most of it came out when the right tire fell off as we tried to pop the engine. That was an adrenaline rush.
old
08-03-2006 19:14:31
 Re: Hey Old... in reply to hillbillyOH, 08-03-2006 18:35:06
Pulling is another way to brake things. My self I alway use the starter motor to try to turn one over. It puts out more torque then a rear tire and your arms does but not enough to brake things unless it has a hyd lock from the cylinders being full of fluid and the plug being in.
Janicholson
08-03-2006 13:05:53
There might be engine dammage if you do. Pull the plugs and hang a rag over the side of the engine to catch oil, then crank it to blow out the trans fluid. Oil does not compress, and thus it might not even turn. JimN
