Tractor Talk Discussion Forum
Valve Train
Bob Guthrie
08-06-2006 10:06:45
I need to replace my valves and valve guides on my 52 8N.
What tools do I need to do this, I can't find the tools listed in the I&T Ford shop Manual
Thanks Bob
Wichita,Ks
old art
08-06-2006 21:20:26
 Re: Valve Train in reply to Bob Guthrie, 08-06-2006 10:06:45
do you have the crazy little tool to hold the tappets from tirning as you adjust them. bet you dont. im a old ford mec. to stop the lifters from turning i would a 1/8 hole in thr side of the guide for the lifter low enough to put the drill bitt in the slot in the lifter to keep from turning when you adjust it DONT RUN WITH THE DRILL BITT IN THE HOLE some one may have done this already. it saves a lot of time in the end.
.when drilling you remove the lifterwont cause any problems with oil pressure the oil will drain back in to the pan you do this to all lifters look it over you shuld see how it works
Bob Guthrie
08-07-2006 12:23:36
 Re: Valve Train in reply to old art , 08-06-2006 21:20:26
Thanks Art
Wish I knew that before I bought the tool
Bob
Bob
08-06-2006 10:15:04
With the manifold removed, insert a curved pry bar into a port, pry the valve guide downward enough to remove the "C"-shaped keeper.
Then, pry the whole assembly upward, and out of the block.
Assemble the new valve, guide, and spring parts and keepers, and install the new assembly in the block, then install the "C"-shaped keeper.
Doing it this way, no exotic tools are needed.
Bob Guthrie
08-06-2006 10:29:17
 Re: Valve Train in reply to Bob, 08-06-2006 10:15:04
Bob
Thanks for the Tip
Do I need valve seals on all valves
Thanks Bob
Wayne Swenson
08-06-2006 19:11:49
 Re: Valve Train in reply to Bob Guthrie, 08-06-2006 10:29:17
Don"t forget to check the valve clearance; you have to grind off the end of the valve stem to get the correct clearance. Do this before you install the C keeper. Very carefully, I might add!!
Bob
08-06-2006 20:12:52
 Re: Valve Train in reply to Wayne Swenson, 08-06-2006 19:11:49
Wayne,
I'm think'in his '52 will already have adjustable tappets... no grinding of the stems will be needed.
Bob
08-06-2006 10:32:43
Check out this thread:
