Tractor Talk Discussion Forum
FWA Horsepower loss
Growler36
08-08-2006 04:59:18
Anybody got an idea how much drawbar horsepower a tractor loses (b/c of tire weight / driveline)when you look at two identical tractors side by side, one with FWA one without?
Thanks..
Growler36
08-08-2006 09:10:07
 Re: FWA Horsepower loss in reply to Growler36, 08-08-2006 04:59:18
I am referring to FWA. Hydraulic. I've had several hours on Ford TW-25, and TW-35 (both with FWA) and really do notice the slippage with the FWA off. I could really tell a huge advantage when crop farming, but was curious about smaller tractors (70-100hp) with FWA. Seems like the FWA really "bogs" these down on hills. I'm really looking for something in the 130hp range and trying to figure if I want FWA OR MFWD. The tractor will be used both in haying AND tillage. Looking for a good older tractor not a new one.
rottenrobert
08-08-2006 07:36:35
I think we need to get the terminology straight:
FWA= Front Wheel Assist, generally hyd powered
MFWD= Mechanical Front Wheel Drive
Which one are you refering to???
Scotmac
08-08-2006 06:09:12
What you would lose in HP, you gain in fuel consumption and acres covered. Run a MFWD through the field and kick it off and see how much slippage you get. BIG differance. Big or small implement, it is very noticeable.
MSM
08-08-2006 05:36:04
The only horse power loss from a FWA would be the extra power drag from the hydraulic pump,which is usually larger than the standard pump,probably at maximum load you would lose 5-7 engine HP over a 2wd tractor. This in most cases would be offset by increased drawbar pull/less wheel slippage.
