Tractor Talk Discussion Forum
freeze plugs
spitz
08-11-2006 13:49:08
I am putting freeze plugs in a continental engine. They are the dish type. What do I need to pound them in? Do I need some type of sealer behind them? Do I pound them until straight or curved in? HELP!
spitz
08-11-2006 21:38:06
 Re: freeze plugs in reply to spitz, 08-11-2006 13:49:08
Thanks guys!! Your help (as always) has been a lifesaver!
bradk
08-11-2006 20:04:20
Dale B is right on this one.I just installed one on an Oliver 60 Continental the other day,and did it like Dale said,although I used a 3/8 socket extention to dimple the center.~brad
Dale B
08-11-2006 19:03:20
Spitz , they are referring to modern Cup plugs. On the Continentals And Flathead Chryslers that use a dish plug, clean the bore of loose rust.( A wire brush in a drill motor is handy here) Put some kind of sealer around the edge of the bore, and set the plug in. Now hit the dome with the ball of a ball peen hammer, denting it in. May require several hits, just don't go past flush. Hitting the first hammer with a bigger one wil improve your aim !!
JGarner
08-11-2006 14:21:55
When I have replaced freeze plugs I just find a socket that is about just the right size to fit in the plug, center the plug on the hole and give it a good whack with a large hammer or hand sledge. If it starts (so it holds itself in) then stick a piece of aluminum plate over the socket or use a large brass rod against the socket and continue pound on it until the plug is at least flush with the block or a bit below flush. They hold every time.
ksb
08-11-2006 18:09:37
 Re: freeze plugs in reply to JGarner, 08-11-2006 14:21:55
third party image
JGarner,Is right on the installation of he freeze plugs (soft plugs). Coat both the plug and hole seat with any nonharding sealer and drive the plug into place. In some/most cases a special driving tool is used to seat the plugs.
