Tractor Talk Discussion Forum
Control arm-3 point hitch HELP
Arthur Ragan
08-11-2006 18:55:12
Re 1958 641 Ford tractor. The control arm that lifts the bushhog is stuck. What should I be looking for to fix it?
Would be much obliged if anyone can help me.
paul
08-11-2006 22:29:53
 Re: Control arm-3 point hitch HELP in reply to Arthur Ragan, 08-11-2006 18:55:12
The hand lever you move is stuck, or the arm on the back of the tractor that lifts the hog is stuck?
Is it stuck all the way up, all the way down, or in between?
--->Paul
Arthur Ragan
08-12-2006 18:59:07
 Re: Control arm-3 point hitch HELP in reply to paul, 08-11-2006 22:29:53
The hand lever is stuck in all ranges. I have removed the nut on the control lever, sprayed in WD-40, then tapped with a hammer to move the lever a quarter inch at a time until I get the bushhog raised. After about 30 minutes, using both hands, I can move it up and down.
