Tractor Talk Discussion Forum
I hate it when
old
08-11-2006 20:50:25
Some one say they have a restored tractor then they say the have problem with it not running right, over heating or a number of other problem. If they truelly did a restore it would have so many new parts on it that it couldn't over heat unless the timing is way off becuase the block would have been hot tanked etc. Sure wish there was a way to define a restore and one made to look good.
To me a restore means its back to as good as when new or better. What say you guys.
And No I don't retore the ones I have I just fix them up and make them run good/look good
B-maniac
08-12-2006 12:24:42
 Re: I hate it when in reply to old, 08-11-2006 20:50:25
How can you say a restoration is "replacing all parts needed"? They are ALL worn beyond new specs! Is a bored cylinder and larger piston "restored"? In my opinion NOTHING that wears can ever be restored in the true meaning of the word. If RESTORED means brought back to 100% original,then it is not possible on something that wears!! I believe this IS the true meaning of the word. This means you can't install a bearing made by Timken in 2005 in a JD made in 1941 and call it restored. And besides,who decides what mechanical parts "need" replaced and which don't? Some you can't tell by looking at them.I would say that any 50+ yr old part has a 99% chance of being bad in some sense of the word.Are you going to replace EVERYTHING in order to call it "restored"? The buying public has an obligation to educate themselves in everything they do.It don't matter how many "rules" or "laws" we institute, we can't protect someone who refuses to protect themselves.The information needed to protect ones self in any situation IS out there.You can either USE IT or LOSE. It is our choice and we need to stop blaming "Words" in an add or "words" that were spoken by a "motivated" seller for our poor bargaining,documenting and purchasing skills.Yes it would be an ideal world if everybody was on the "same page" in all our deallings,but the last time I looked, this world is not and never will be even close to "IDEAL".
Gary in Mozarks
08-12-2006 12:23:04
I ran into a problem once when I rebuilt a 460 Ford truck. With new tight rings and bearings, it overheated. I first replaced the theromstat, then pulled the heads and replaced the headgaskets, Then I tried boiling out the radiator, then a different used radiator. It took a new radiator to fix it. Sometimes restoring one part will overload a different part.
CNKS
08-12-2006 09:37:17
I like the term --refurbished-- which to me means those broken or excessively worn parts are replaced. Another way of using the restored term is to do what I sometimes do when referring to my own tractors, I put it in quotations "Restored". There are very few truly restored tractors around. The 460 I am "restoring" will have a completely rebuilt engine. But the somewhat worn transmission will be untouched except for a thorough cleaning and new fluid. As to the paint, I am not about to use the 1930's alkyd enamel that came on them. My objective there is to make it better than new. I don't get excited when I see the term, I just pass it off and take it with a couple of grains of salt.
Don-Wi
08-12-2006 08:52:58
I guess I'll jump in here too.
About 15 years ago my dad traded my Grandpa's old Ford loader tractor (I think it was a Jubilee) for a Massey 165 w/loader he found while servicing the parts washer at a dealer in Door County. The 165 was repainted and it looked great, even though it wasn't thew right color scheme. It was just painted because I'm sure it spent a good deal of time in the manure. It's a great tractor, I don't think it was advertised as "restored" or anything like that, but it probably was the new paint that attracted my dad to it. Now 15 years later the paint is really rough and quite a bit has chipped off where it was applied right over the old paint, making it look REALLY rough.
I restored my Grandpa's Oliver 1600 over the last few years and I'm still tinkering with it. The only thing I didn't tear into was the rear end, but I had no reason to because it worked fine and didn't make any noises. I had the engine rebuilt by a professional, so it was COMPLETELY torn down and hot tanked, crank was ground 10/10, and I had an overbore kit installed to bring it up to 1650/55 specs. I had LP exhaust valves installed and hardened seats, so I guess that isn't "factory correct", but it is an update to make it run better.
I had my brother paint it with a 1-stage automotive paint with hardener so it would be durable. My ollie sits outside a good deal of time, plays in the mud, and still has to earn it's keep around here.
The one thing I regret to a point, is having misc. parts chromed. Some of them were done poorly and are starting to rust a little bit. I complained to the guy who did it and he said "well you gotta polish it and wax it constantly and keep it clean." I'm sorry, but I don't have time for that and why does a truck bumper not rust to sh!t when the owner doesn't wash it all the time. I know it'll go quicker, but what's rusting on mine isn't anywhere near the mud. They were just done poorly.
In my eyes, that's what a restoration is. It doesn't have to 100% factory correct, but it should have a fresh engine, good paint, new tires if the old ones are shot or weather checked, (unless of course you can't find that size anywhere) And if you have to, go through the rear end.
What doesn't count is either just a paint job, just a new engine (come on now, thats just overhauled) or a new paint job and new tires, without ever opening up the engine to inspect things.
Donovan from Wisconsin
Billy NY
08-12-2006 03:59:12
How many times have we seen the discussion on this and the wide array of definitions based on the different opinions given on the subject.
With that in mind, and thinking how many things in the technical world have been standardized, supported by society of this or society of that, which created a reference standard so everyone is on the same page, or going by the same standards.
Now these are tractors, all manufacturers considered, you could easily designate the major and sub categories of restoration, condition or repairs, and to meet that designation you need to qualify by performing X amount of work on said tractor, be it a combination of mechanical and finish type work. Everyone has their own idea on this, but if a guideline were established, and an acceptable means of documenting such classifications of restorating were established, certainly would make it easier for a buyer to understand what he or she is looking at.
Personally, be it cars, trucks, tractors, and you use the word restoration to describe it, say 100% restoration than I would like to think that should mean a complete tear down, or inspection of all components and a neatly done re-assembly with new parts as required to make the said unit as factory correct as possible, forget about the finishes, that will be a preference, now say you want a museum quality restoration well that may a apply to someone who will not polish the castings and use high gloss automotive paint etc.
Restoration A - Factory Correct / Museum Quality
Restoration B - Factory Correct / Auto. Finish
Restoration C - Factory Correct / Mechanically sound in good working order, orig finish
Restoration D - Mechanically Sound / Original finish field ready
I dunno, at least by organizing it, you could possibly level the playing field, of course the bad guys would probably forge the documents verfiying the class of restoration or condition.
One car I did was a plain jane 78 vette with a 350 chevy, 4 bolt main, steel crank, beefed the motor quite a bit, just under 400 HP, matched the trans with a slight stall out converter, suspension, drive train and tires and brakes, painted chassis and body, kind of a frame off restoration, ran fine as long as I had it, but it was just about completely taken apart and re-assembled.
Bob
08-12-2006 00:32:38
You say "To me a restore means its back to as good as when new or BETTER."
That's the part I don't understand.
To me, RESTORE means to put it back as it was when it was NEW. Yet, to some, RESTORE means a $5000 automotive paint job. While there's certainly nothing wrong with that, that's NOT how the old beasts left the factory!
To the purists, every nut and screw has to be as-original, yet they smooth the castings, and paint them up like a shiney new 'vette, with exotic paint.
So, why the fanaticism about the correct details, and then ignore the original enamel paint?
4010guy
08-11-2006 21:25:53
HA, around here when somebody says its restored like new it means somebody repainted it. ;o)
NC Wayne
08-11-2006 21:20:59
I've always said the same thing about cars, trucks, anything that has been "restored". I can't count the number of articles I've read, shows I've seen, etc where somebody "restores" a vehicle, be it to origional condition or modified, and proceeds to tell about all the problems they had with it on it's first real trip. I did a 55 Chevy wagon back in '86, fresh out of high school. I drove that thing for 4 years, 400 plus miles back and forth home everyweekend I got a chance, and never had a major mechanical problem. I guess it all comes down to the old adage about if your gonna do something then do it right.....
Steven@AZ
08-11-2006 21:04:46
Well, I would say my 42 H is mechanically refurbished - meaning all parts that needed to be replaced were. The engine is as good as or better than new. It was hot tanked, magnafluxed, and a major overhaul performed with all new parts in the head, ground crankshaft, etc.
Restored would mean that I need to paint it yet, and put new tires on it.
MSD
08-11-2006 21:39:41
 Re: I hate it when in reply to Steven@AZ, 08-11-2006 21:04:46
I overhauled my 720 diesel a few years back. Bored the block, planed the head, rebuilt injectors, rebuilt rack everything that needed replaced was. Tried starting it and it ran like a clock right off. I decided to put it to work and it overheated as soon as I pulled it. I thought maybe the new thermostat was bad so took it out. Still overheated. I finally decided maybe I should have had the radiator flushed. I pulled it off and found out there was a big old mouse nest in the top tank that plugged everything up. It wasn't in there when it came off the tractor but after sitting on the floor in the shop for a month, it made a good home for the mice to make a nest. I plug all the holes on anything sitting around after that episode. Thing is stuff happens no matter how carefull you are. I was lucky I didn't do a paint job on it right away and then have to pull the tin off again.
