Tractor Talk Discussion Forum
60% chance my hay is going to get wet: :( windro
plumboy
08-14-2006 08:51:01
Its at about 35-40% moisture with the dew that cant get burnt off.The sun isnt breaking through and rain is about 6 hr away.It about 8acre of red clover,pretty good stuff and I hate to lose it.I cut sat morning,tedded yesterday morn and didnt sleep a wink last night.Anyways,should I go ahead and windrow or leave it tedded out?I am ready to jump in and bale it at a higher moisture by cranking up the persavative,but even tho I use an accumulater it still takes time to get it up.Theres prolly 650 bales.Really dont know what to do,take a chance and get caught in the rain with bales on the ground,baled at a higher moisture(persavative=$),or leave it and see how much rain we get.Plus I could bale,get crappy bales in the barn and only get a spit of rain.This hobby has its ups and downs.Sorry for the rant...I guess my question for you more experienced is rake or not.
Sid
08-14-2006 20:33:02
 Re: 60% chance my hay is going to get wet: :( wi in reply to plumboy, 08-14-2006 08:51:01
I know I am a little late to be of much help. You gotta look at it on the bright side. There is a 40% chance it will not get rained on and better than 50|50 the weatherman is wrong. So the odds are in your favor. We have baled red clover a little on the green side then salted it down as we stacked it in the barn. Cows loved it.
Errin OH
08-14-2006 12:05:17
I'd wait. Just made 700 bales of clover/grass (70/30) myself. Some of the best I have ever made. Seems I am always fighting stem moisture in clover. Really bad when the humidity is up. Takes forever to get ready. If it seems to wet now just wait a day or so after you bale it. I have had it come out black as a used motor oil and hard as a brick. It tested 15-18% baling and a day later was above 30%. Cows don't seem to mind. But I doubt you could sell it.
Like others have said, I'd rather put up low(er) quailty hay than moldy wet hay (junk).
Dave from MN
08-14-2006 09:51:35
If it aint dry enough, its could rain at any moment. I would leave it sit as is and see what the weather does. If it rains then clears up to a nice drying day or 2 youll be ok. I myself would not want the chance or having 650 moldy heating bales. I wouyld rather have 65 good bales that happened to get rained on a bit. Just my opinion. Good luck
sd pete
08-14-2006 09:45:55
Worrying about hay getting wet puts you in an early grave. Let be till its dry enough
plumboy
08-14-2006 09:03:03
Heres a pic of the stuff.I dont know why I cant publish the photo here.All it will let me do is a hyperlink.
Jim.UT
08-14-2006 15:04:59
 Here's your pic in reply to plumboy, 08-14-2006 09:03:03
third party image
I hope.
plumboy
08-14-2006 16:13:48
 Re: Here's your pic in reply to Jim.UT, 08-14-2006 15:04:59
Thanks jim.Wonder what I could be doing wrong...
