Tractor Talk Discussion Forum
need hydraulic valving help
fred kobs
08-15-2006 03:17:04
Okay, here goes. I have a 44 Massey with a 1-way loader on it. Years ago we removed the mounted third link cyilnder/factory hyd. valve and installed a 1 way valve to operate loader. I built a wood splitter that I want to tie in and run 2 way. I need to figure out (cheaply of course) how to plumb the system up to operate a valve mounted on the splitter, the loader, and would like to have a 2 way hook-up mounted on tractor. Any and all help appreciated. Thanks. Fred
J Schwiebert
08-15-2006 05:00:19
 Re: need hydraulic valving help in reply to fred kobs, 08-15-2006 03:17:04
Ah there is the magic word "money" again. First of all how about a "splitter valve" so you can run your loader and your log splitter and a two way valve. Or use a 2 way valve with power beyond and use the power beyond to run the loader and the splitter? If you get a 2 way with a second spool for float, use the float spool to run the loader. Many choices, tell us what is in your budget. Questions? J.
