Tractor Talk Discussion Forum
Tapered box steel for ROPS
Josh in Pa
08-15-2006 07:29:32
I'm looking into building a roll-bar and canopy for my Oliver 1655 because they are very hard to come by. The uprights are tapered box steel, and I am unsure how to construct them. My only idea has been to take a rectangular section, slice a thin triangle out of it, and then weld it back together. This way it would be say 2"x6" at one end, and 2"x4" at the other end. Anyone ever done this before? Thanks for any tips,
Josh
buickanddeere
08-15-2006 14:55:52
 Re: Tapered box steel for ROPS in reply to Josh in Pa, 08-15-2006 07:29:32
You can't build a rops for less money than Deere sells rops re-trofits. Don't know if Agco does the same favor for thier customers or not. Try Lorin in Quebec or Safe-t-cab. As for building your own rops and counting on it providing protection in case of a incident? Don't. When very experienced and educated engineers tip tractors over. They get suprised where the rops or the tractor it's self breaks. A failed rops is worse than no rops at at. Makes it more difficuilt for emergency responders to remove bodies too.
Don-Wi
08-15-2006 09:41:48
You could go to a weld/Fab shop and have them make the channels out of 1/4" or thicker sheet steel. I'm pretty sure that's how the originals were done, cut a sheet to the right size and then fold the 90 deg. bend on it.
I know you're probably looking to do it cheaper, but if you're concerned with it actually having to hold something, that's the way I would go. The fewer the welds the better.
Donovan from Wisconsin
Josh in Pa
08-15-2006 09:54:37
 Re: Tapered box steel for ROPS in reply to Don-Wi, 08-15-2006 09:41:48
Do you mean to make the whole box, and then run one weld, or make two channels and then a weld on each side to join them? Making the box and using one weld would be a really slick looking job, but I'm not sure how you could bend a complete box. I'm not familiar with metal working though. I followed your progess on the 1600, sure hope my 1655 looks that good someday. Josh
Don-Wi
08-15-2006 23:22:26
 Re: Tapered box steel for ROPS in reply to Josh in Pa, 08-15-2006 09:54:37
You'd make each pillar out of 2 halves, welded together. I could look at the rops on our 1855 tomorrow but I'm pretty sure that's how it was done.
JDknut
08-15-2006 09:06:48
I designed and had fabricated one for my White 2-85 out of rectangular tubular stuctural steel, A500 grade, yield ~50,000 PSI. All welding was ultrasonic grade full-penetration, low hydrogen. You need it for the low temperature toughness. It wasn't worth it to mess with tapering it and all that jaxx. Total cost about $550 in 2000, plus a few bucks for my fire chief to help me set it on my White with his Deere 7210.
nballen
08-15-2006 08:44:36
Might be better (easier, cheaper, simpler) to just leave the full 2x6 section. Unless you are REALLY worried about being top heavy (I just don't see that on a 1655) the extra weight won't hurt you a bit. My gut sense tells me that the extra weight you pull out of the ROPS won't save you anything, especially since you are buying stock sections and having to cut and reweld.
When a manufacturer buys steel by the pound, and can save some weight by fabricating a special section for dozens (or hundreds) of units, the savings add up to be worthwhile. For a single unit (what you are building) you don't recover the cost of making that special shape.
Nathaniel
buickanddeere
08-15-2006 19:37:48
 Re: Tapered box steel for ROPS in reply to nballen, 08-15-2006 08:44:36
The taper on the posts of a rops is designed in to allow it to spring gradual and flex some to absorb the crash energy. Otherwise the welds at the rops base, the clamps, the tractor axle housing of belhousing may snap. Very similar to how leaf springs are staggered in length. Initially a little pressure causes some deflection but as the weight/pressure on the springs increases, the spring rate increases.
Josh in Pa
08-15-2006 09:27:48
I'm not at all worried about weight, but I would like to have it look as original as possible. I have located a few originals to measure and photograph, and think that I can build one very close to the originals. It might not be as easy or cheap, but to me its worth the extra effort.
Josh
Gerald J.
08-15-2006 07:56:00
If you don't have a press brake to fold up the pieces from flat steel, that's how you get there. You might not need to start with 2x6 split down the middle, but maybe 2x2 with one face cut off with a filler wedge.
Or maybe just a bit heavier and with less cutting, leave the tubing pieces 2x2 and space the bottom ends and put in filler wedges. That middle web won't do much for fore and aft bending strength and will add weight but it will make it stronger side ways. And those two sides left inside not being cut of saves a whole lot of work.
Gerald J.
