Tractor Talk Discussion Forum
GM 6.5 diesel???
Tx Jim
08-15-2006 11:01:13
What's a good website for diagnosing a problem on a 2000 model? Thanks,Tx Jim
Tx Jim
08-16-2006 03:46:23
 Thanks in reply to Tx Jim, 08-15-2006 11:01:13
Engine starts,runs for while,dies, starts,dies starts!!!! Codes U1192,P1626,P1216 and P1217 showed up on scanner but mechanic didn't know what to repair. PMD was relocated earlier. Thanks,Tx Jim
Kevin (FL)
08-16-2006 05:28:17
 Re: Thanks in reply to Tx Jim, 08-16-2006 03:46:23
Are you sure there's no air in the system? Did you just change the filter or has this been happening for awhile? We have a 1995 6.5 that I maintained for a few years and I've had the same problem. Also did you check the lift pump function? If it's not working run a temporary wire to the pump to see if it's good. If that works then the oil pressure sending unit may be bad. This is where the lift pump gets it power after start-up. (Not sure if the 2000 model is set up the same way.)
Tx Jim
08-16-2006 06:39:00
 Re: Thanks in reply to Kevin (FL), 08-16-2006 05:28:17
No air in system,new fuel pump installed about 5000 miles back and lift pump runs when ing. is first turned on. TX Jim
Kevin (FL)
08-16-2006 07:44:51
 Re: Thanks in reply to Tx Jim, 08-16-2006 06:39:00
Sounds like the injection pump is defective. Before I went that route though, have you opened the bleeder valve on top of the filter housing to verify good fuel flow from the lift pump?
thejdman01
08-15-2006 18:42:05
 Re: GM 6.5 diesel??? in reply to Tx Jim, 08-15-2006 11:01:13
www.dieselplace.com has a specific 6.5 forum
thejdman01
08-15-2006 18:43:46
 Re: GM 6.5 diesel??? in reply to thejdman01, 08-15-2006 18:42:05
excuse me theres no www. its just the Link sorry about that
Jak
08-15-2006 13:44:20
Search the web,there are several websites.I learned enough to decide mine was going to another home.I had a 98 model that stump broke me.Something all the time with mine.PMD NEEDS to be relocated to the fender well for sure.
Doug Wilkins
08-15-2006 12:55:31
What sort of trouble are you having??
dab
08-15-2006 11:11:19
ssdieselsupply.com;gmdiesel.com
