Tractor Talk Discussion Forum
Storage bin prices?
Dave from MN
08-17-2006 08:07:46
Any one recently erected a smaller storage bin for grain- corn/soybeans, oats / etc. I need to get one up in the next year. I suppose I'll start with a 2000 bushel or so size. Is it wise to get a drying bin or a waste of cash. I dont want to get caught having to sell for market price during harvest and will need corn for them there critters were getting. And if I can pick up them there 60 acres next to me that'll help equally distribute my 12 semi loads of chicken poop I have every year. I thought about going with cob corn and cribs, but with the hen barn and a woods right here, I dont want to deal with an influx of rats and mice.
paul
08-17-2006 21:20:42
 Re: Storage bin prices? in reply to Dave from MN, 08-17-2006 08:07:46
How you going to dry your shell corn?
You can store crops without a fan until June. After that, it gets dicey _some_ years.
I'd sure start with a bigger bin, and put in a floor - if you are doing corn. You might wish to store your corn longer.
Oats will store a long time with no air, and beans you should _not_ be keeping longer than June anyhow, so those crops wouldn't matter.
The big expense of a bin is thew concrete. New bins cost a lot, used ones sell cheap, but take a lot of work.
I moved a 1500bu on the place on the back of a hayrack. I got 2 govt bins as mentioned above from the farm next door, still had to dismantle 2 rings each to get them under the power lines.
So, you plan to end up with 3 bins, small for oats (or over-flow from other crops), medium for beans, and a bigger one for corn.
I'd scour the neighborhood for good used small bins. You can't afford to buy a new one under 10,000bu.
You need to explain your drying plan for the corn be4 any thoughts on what the big bin should be.
Picking 40 acres or less is _far_ cheaper in the long run considering drying, the equipment is cheap, only need cribs & they sell for $5 at auction sales. It is slower tho.
Got any old feeding platforms or other concrete you can set a bin/ crib on?
--->Paul
paul
08-17-2006 21:24:26
 Re: Storage bin prices? in reply to paul, 08-17-2006 21:20:42
Oh, $400 per bin was I thought a fair price for the govt (~3500+ bu) bins. So did everyone else at the auction. The rusty ones went $150.
The 1500 bin I gave them $40 for helping me load it. It was in their way.
Be sure you plan for the future, laying concrete is $$$, you are putting the bin there for a long time. What if you pick up yet another 60 acres, got room for more bins/ storage - don't hog the middle & wish you had more room....
--->Paul
super99
08-17-2006 18:16:28
I would suggest looking for a used Gov't bin. 18 ft. dia.,about 4000 bu. Small enough that they can be laid on their side and moved to your site, just need to find route with no low power lines. Lot of work to tear down and move but if you have plenty of help, not that bad. Paint a line from floor to ceiling inside bin and number each sheet and ring and put it back together the way it came apart. should be able to rent bin jacks for a week. Several guys around here are set up to move 18 ft or smaller bins. Check around. my 2 cents worth.
Chris
super99
08-17-2006 18:15:19
Chris
OldTimeFarmer
08-17-2006 15:44:22
You can buy used bins for relatively low prices, but it will involve work. I've seen several real good condition bins, 10,000 bu., with complete floors, fans, stirators and some with floor dryers, for $3000-$4000 bucks, some cheaper. First, you'll probably have to hire someone to move the bin. Second, you'll have to bust out the ventilation and fan from the existing bin pad. Third, you'll have to pour a new concrete pad at your site.
A 2000 bushel bin is too small to store much grain. Say your corn goes 150 bu/acre, that's about 13 acres you can store.
The good thing about drying your own grain is (1) you get to keep your own corn; and (2) you can dry it down to 13-13.5 percent moisture for long-term storage.
Make sure you have a distributor in the bin opening when you fill, or you'll get all the fines/dust in the center of the bin and you'll get compaction in the middle of the bin, both of which will lead to the grain to heat in the center of the bin.
If you had a batch dryer (not in the bin), many of these did a good job of screening the corn. Otherwise, I'd try to rent or pick up a grain screener. It's a challenge to move air through corn that's full of fines, because the fines and dust "fill in" all around the kernels, making difficult to move air through it.
Don't fill the bin above the "shoulder," where the roof meets the bin side, and make sure to level the grain off once you get the bin full, especially if you don't have a distributor.
glennster
08-17-2006 11:13:21
i bought 3 used bins a few years ago, 1- 14000 bu drying bin, 1 14000 bu storage bin, and 1 8000 bushel drying bin. paid 5000.00 for all three, both drying bins has stir-ator units in them. we moved them ourselves. its quite a bit of work.
RustyFarmall
08-17-2006 08:59:06
Been too long for me to have any real insight on bins, but I think you would be wise to at least add the drying floor and a small fan to at least blow some air through the stored grain, just in case the grain was not quite as dry as you thought it was.
