Tractor Talk Discussion Forum
hyd oil question
ron,ar
08-18-2006 19:58:22
Anybody here familar with Mobil AWG-32 hyd oil? What is it supposed to be used in? Can I mix it with the hyd oil in a Case 580C? Thanks for input.
dej(JED)
08-21-2006 05:56:35
 Re: hyd oil question in reply to ron,ar, 08-18-2006 19:58:22
ISO 32 oil is very light. It is for sophisticated hydraulic piston type pumps. I favor ISO 46 for most evrything I run. It holds up better under heat.
NoahW
08-18-2006 21:37:54
AW=Anti Wear. 32=ISO weight, =10 wt. oil. It is OK for straight hydraulic systems. I use any brand AWG32 cheap stuff in my systems year around here in NC. Hoses bust: why spew expensive oil all over everything. Wouldn't use it in transmissions that call for mfg. spec. #'s though. It doesn't have the additives that the speced oil has.
