Tractor Talk Discussion Forum
966 fuel consumption
Greg in PA
08-22-2006 16:56:29
On one of my other posts I stated I was using 1 1/2 gal per hr haying. One fella mentioned the best he was getting was 3gal per hr. What are you guys gettin.
Greg
BigMarv1085
08-23-2006 05:14:08
 Re: 966 fuel consumption in reply to Greg in PA, 08-22-2006 16:56:29
Hey, Greg like I said when mine is pulling a chisel plow or 3 row subsoiler, mine will burn up to 7 gallons. I don't know if the pump has been turned up or not. I don't use it very much because it is so bad on fuel. Cutting hay or pulling a round baler, its more like 3. I cant see the tach because the cover has faded but I know it tachs out at 2600 rpm, what does your or Allens tach out to.
Greg in PA
08-23-2006 14:09:30
 Re: 966 fuel consumption in reply to BigMarv1085, 08-23-2006 05:14:08
Yes the tach goes to 2600. I am only runnin 2000 at best with the square baler though.
MN Scott
08-22-2006 20:11:42
My 1066 uses 3.5 gal per hour running a New Holland 1411 10ft. discbine in heavy hay and its not even making it smoke. I've never checked it plowing but it must be in the 4 to 5 range but I suppose if I was just running a square baler it might be around 2 GPA?
Rich in NY
08-22-2006 18:12:57
At the risk of starting a brand war here, with my 4020 (near the same size) I figure about 3 to 4 gal/hr depending on the job. I wouldn't be surprized if I really had something to make it work it would burn 5 gal/hr, but even chopping you spend a fair amount of time idling changing wagons. Thats going by the hour meter on the tach, so with light work where I'm running only half or 2/3 throttle the clock on the tach runs slow and I may be getting 2 gal/hr real time. 1 1/2 gal/hr sounds excellent.
Allan In NE
08-22-2006 18:02:52
Greg,
Are ya sure it's running? Mine makes a rappidity, rappidity sound. :>)
Allan
Greg in PA
08-22-2006 19:21:55
 Re: 966 fuel consumption in reply to Allan In NE, 08-22-2006 18:02:52
Well i think so??? I ran 7 hrs on it and put 9 gal back in it and it was filled both times to the bottom of the neck. Yes it had some idle time but it still averages 1.3gal per hr. Is there somthing wrong with me????
Greg
the tractor vet
08-22-2006 19:32:56
 Re: 966 fuel consumption in reply to Greg in PA, 08-22-2006 19:21:55
Now you may be getting that but myself i would want to run it on a dyno to see if it is running what it should be i can't get that economy on the 806 on lite work and it is a smaller engine oh wait i got it tweeked .
