Tractor Talk Discussion Forum
nuffield 460
melvin merrill
08-24-2006 07:48:26
i wanted to change the rear end fluid.but was wondering what kind of fluid i should put in to it.it has the hyd pump in the rear end.any help would be appreciated
oli
08-24-2006 15:02:46
 Re: nuffield 460 in reply to melvin merrill, 08-24-2006 07:48:26
Well, if you want to do it by the book you should use the same oil as the engine uses, i.e. 30 weight (or whatever), but i"ve used trans-hydraulic fluid for years in my 10/60"s without any problems. That said if/when the hydraulic pump starts to go heavier oil does make quite a differance. Hope that helps. Oli
