Tractor Talk Discussion Forum
Transplanting Trees with a Backhoe
Old Hickory
08-24-2006 23:08:15
Does anyone have any expereince in transplanting hardwood trees 2" or less in diameter using a backhoe? If so, would appreciate any advice as to the best way to dig the tree and transplant with the best chance of tree survival. Tks.
Old Hickory
08-25-2006 17:46:41
 Re: Transplanting Trees with a Backhoe in reply to Old Hickory, 08-24-2006 23:08:15
Thanks for all the advice. I have an avenue that is about 1400 ft long to my house. There are a number of oak, walnut, black cherry, red cedar, holly growing wild on the farm that have come up from seed. My goal was to move a number of these trees to line the sides of the avenue and after establishing a variety of these trees, start to fill in with understory trees like crape myrtle, dogwood, camelias etc. Would you think it would be better when digging the tree, to first dig a hole with the hoe at the drip line of the tree and then drop the hoe in the hole at a 90 degree angle and scoop out the tree or should I just scoop it out with the bucket with one scoop. I"m assuming the tap root goes down a fair ways even on smaller caliper trees. Thanks again for the thoughts.
williamf
08-25-2006 06:19:18
third party image
I've done that some. The picture is Old Stoney and me, moving a clump of pampas grass. Success with trees and shrubs depends mostly on variety, I think. The more robust types (I've had near 100% success with hollies, crepe myrtles and ligustrum) will do well where more tender sorts (think dogwoods) will wither when you walk up to them with a shovel. As for technique, I'd recommend always dig the destination hole first. If you get where you're going and have to dump the transplantee and then pick it back up after digging a hole you've tripled the trauma. Prepare the hole as you would for any new planting - good size, good dirt, compost, mulch. Be prepared to water daily for the first week or two, regularly after. Never let it get too dry. When you go after the plant use the hoe to cut into the ground around it at the edge of where you think the root line will be, well out past the edge of the branches. Then when you scoop try to go for as much root and dirt as you can get in one scoop. I find that it helps when carrying the plant and root ball from place to place to have a load in the front end bucket. Makes steering more comfortable. Hope this helps.
Good luck, Wm
Old Pokey
08-25-2006 06:02:36
Problem I've come across is when digging the tree itself with a hoe, the soil disturbance will tear a lot of feeder roots and even break some of the others. Then when you release the tree from the hoe bucket, the root ball will be even further damaged, if not completly disintegrate. If the tree is only 2", it is very easy to dig by hand. You can still dig the hole on the other end where the tree will be put with the hoe.
A google search on transplanting trees will give you several ideas and recomendations for root ball size.
LeRoy DeLong
08-25-2006 05:39:45
My youngest brothers and I have done it several times with good luck. You have to wait till fall time when the sapp has gone down out of the tree. Just make sure you get plenty of soil with the tree.
