Tractor Talk Discussion Forum
Way off topic,,kitchen stove?????
SJ
08-28-2006 09:15:36
A while back one of the electronic igniters on one of the burners quit working,didnt pay much attention to it.Now none of them work.Anyone know about these? Do they have to be cleaned,replaced?
Thanks Stan
Bluedice
08-28-2006 17:31:21
 Re: Way off topic,,kitchen stove????? in reply to SJ, 08-28-2006 09:15:36
I think electric stoves have one central spark generator which does all burners at once. You sometimes can "lift the hood" of those stoves by simply lifting up on the stove top just above the door. If you are missing the snapping sound you probably need to replace the "coil" or whatever makes the spark. If not may just be lots of old mung around the metal surfaces -Emery cloth-
Cosmo
08-28-2006 14:31:11
Ain't progress wonderful? I had a gas stove for about thirty years and the old standing pilots never went out. Yes I know it used a bit of gas but what the hey. They were there when needed.
RAB
08-28-2006 14:57:17
 Re: Way off topic,,kitchen stove????? in reply to Cosmo, 08-28-2006 14:31:11
Cosmo,
Multiply that "bit of gas" several million times and for 30 years. That is some waste of a resource, which is reducing by the day. Apart from the increased explosion hazard. Get a bit green and do a little to help save the earth. It needs everyones help. Hope you never complain about the changing weather cycles and global warming (which are now fairly certainly caused by us humans mucking up the equilibrium), the price of fuels, etc.
RAB
Cosmo
08-28-2006 16:06:11
 Re: Way off topic,,kitchen stove????? in reply to RAB, 08-28-2006 14:57:17
Nice soap box you have there RAB. I'm impressed.
Matt Kane
08-28-2006 12:31:41
I clean the grease off of the contacts, and clean the centers of the burners, then take some fine emery cloth to clean up the contacts on the burners. I do that and I have no problems. If not either replace them or use a long lighter.
RustyFarmall
08-28-2006 11:45:15
Ours is the same way, except ours still click and sound as if they are working, but nothing happens. Kind of a pain in the you know what to use a match.
mjbrown
08-28-2006 11:20:32
My stove, made by Brown (go figure) did the same thing and the unit is down inside the stove meaning it would have to be disconnected from the gas , pulled out and disassembled to fix it. I bought a couple butane gas grill lighters and use those. The oven has a pilot when in use so it holds temp just fine.
Dachshund
08-28-2006 09:59:55
Had one of them once - it had the same problem so I just turned the burner on and lit them with a match. Luckily, the oven one still worked (you can LIGHT it with a match, but it won't hold temp). On mine there was an electronic gizmo that tied all of the burners together - finally replaced it and all was well.
